Fine Engraving
Fine Engraving
Postby Rburke » Sat Apr 09, 2016 2:56 am
Hi,
What wood species are best for holding fine detail in small engravings? Also, considering applying something like a lacquer or shellac to penetrate the wood fibers to hopefully keep from losing detail. Any suggestions on what works best? I am currently using a .005" tip, 30 degree v-carve bit running at 18,000 rpm @ 45 ipm. Depth at .01". Engraving soft maple.
Rburke
Model of CNC Machine: Stinger 1
Re: Fine Engraving
Postby Xxray » Sat Apr 09, 2016 3:41 am
I like purpleheart for fine machining characteristics, though the one pictured isn't exactly small at 13x8".
Wenge is very good too if you can find it. Walnut is no slouch either, though that can vary by sub species.
sorry about the sideways, I am really getting sick of that and am so tired of having to play around with them to get them to view right on one forum to the next.
Xxray
Re: Fine Engraving
Postby Rburke » Sat Apr 09, 2016 5:23 am
Thanks for the info. No problem with the picture. Very nice by the way.
Rburke
Re: Fine Engraving
Postby scottp55 » Sat Apr 09, 2016 1:34 pm
TREE is Hard Maple
MOOSE is Bloodwood
OLD TOWN is Black Walnut and surprised me.
All done with same bit as you, except a .01" tip.
thin CA STUNK
50/50 thinned Laq was pretty good.
Best was a 50/50 mix of polymerized Linseed/citrus thinner applied the day before, and carved the next day.
Edit;
Run toolpath twice and there will be almost no sanding required. To preserve detail try a good stiff bristle brush instead of sanding on fine details.
A mini burnisher, or bamboo skewer can do wonders also.
Re: Fine Engraving
Postby Rburke » Sun Apr 10, 2016 5:19 am
I appreciate the advice and the pictures of the beautiful work. Really incredible what can be done with these machines. I am going to look at trying hard maple with the 50/50 solution of linseed.
Roy
Rburke
Re: Fine Engraving
Postby scottp55 » Sun Apr 10, 2016 12:42 pm
Oh, Watco Natural Danish Oil works well also, If you have problems finding Polymerized Linseed;
http://www.earthpaint.net/product_Linseed_Oil_Finish.php
IF you are really cutting only .01" deep, then it's imperative that wood be surfaced by your machine, and then sanded to finish grit before carving.
If VCarving TrueType fonts, then maybe go .02-.05" flat depth to avoid losing details.
IF bit is entered accurately as an engraving bit, then a 15-20% stepover gives an excellent pocket finish at the flat depth.
If carving full 30degree depth, then for fonts less than .2" height, it helps to drop down to 30IPM X,Y and slightly lower for Z to prevent bit from plunging in fast and pushing wood in delicate letters sideways and breaking the wood on previous letters.
Re: Fine Engraving
Postby COWBOY1296 » Sun Apr 10, 2016 2:55 pm
Cherry is not bad either, although black walnut is my favorite. I have never tried purple heart but like the picture. I like african mahogany but not really for 3-d. This army logo was 9 inches round but the letters in the Motto "This we will defend" are less than .2 of an inch and it still picked up the lettering using a 1/16 inch bit.
COWBOY1296
Model of CNC Machine: SHOPBOT BUDDY PRS 32, 4 FT PWR STICK
Re: Fine Engraving
Postby Rburke » Thu Apr 14, 2016 4:58 am
If you don't mind, what bit were you using to carve the tree in the hard maple?
Rburke
Re: Fine Engraving
Postby Rburke » Thu Apr 14, 2016 5:09 am
Thank y'all for all the great advice and examples. I think I need to step up my game in the type of wood I am using, as well as change speeds, plunge rates, ... You are creating better detail with a larger flat tip. Still have a lot to learn.
Rburke
Re: Fine Engraving
Postby scottp55 » Thu Apr 14, 2016 2:24 pm
Every one I had pics of was done with the Onsrud 37-23.
http://ballewsaw.com/onsrud-37-23-single-flute-sc-engraving-tools.html
