looking for a tree file
I am looking for a tree file that lookes like the attached picture. Any help would be appreciated.
Re: looking for a tree file
What kind of file??
You can probably get a good trace off of that itself if you want vectors. Or you can import it as a 3d component if that's what you want.
- Model of CNC Machine: Self Built Router and Sieg SX3
Using a File is not advised for a Tree as a Rasp would cut better
- FixitMike
And a raspberry to you, too.Imagineering wrote:Using a File is not advised for a Tree as a Rasp would cut better
From Wikopedia: "Blowing a raspberry, strawberry or making a Bronx cheer, is to make a noise that may signify derision, real or feigned."
This took less that 5 minutes. File attached
I used the bitmap trace on the image you provided.
I used a prism Vcarve, a pocket, and a profile.
- TreeSign.zip
- (573.47 KiB) Downloaded 243 times
