Surface Board
Surface Board
Postby knowlzy0791 » Wed Feb 24, 2016 8:01 pm
Hey everyone,
Any thoughts on what spoilboard to use for a large machine? I use 48"x120" and I think my 3/4" low-density particle board is killing my suction.
What does everyone else use?
knowlzy0791
Model of CNC Machine: PAE 110SD Series/Mach3 Software
Re: Surface Board
Postby martin54 » Wed Feb 24, 2016 9:31 pm
Have you checked your vacuum system to ensure there aren't any leaks? Guessing you already have it zoned so you can shut off sections not in use. Have you sealed the edges of the board? Just doing that will make a difference.
Re: Surface Board
Postby knowlzy0791 » Thu Feb 25, 2016 9:02 pm
martin54 wrote:Have you checked your vacuum system to ensure there aren't any leaks? Guessing you already have it zoned so you can shut off sections not in use. Have you sealed the edges of the board? Just doing that will make a difference.
Yes to all of the above. We just upgraded the blower to one that is supposed to create about twice the suction of the old one, and have not got any real enhancements. I am afraid the board is what is suffocating it.
knowlzy0791
Re: Surface Board
Postby ger21 » Thu Feb 25, 2016 9:14 pm
Are you really trying to pull vacuum through particle board, or did you mean to say MDF?
ger21
Re: Surface Board
Postby Rcnewcomb » Thu Feb 25, 2016 9:33 pm
I assume you machined both sides of the spoilboard, yes?
What is the vacuum gauge showing while the system is running, i.e. are you dealing with a leak or is the spoilboard not allowing air to move through?
Re: Surface Board
Postby knowlzy0791 » Mon Feb 29, 2016 9:11 pm
ger21 wrote:Are you really trying to pull vacuum through particle board, or did you mean to say MDF?
My mistake, I meant MDF. I have went through and checked for leaks on all of the piping and machined both sides of it. The issue is not enough air moving through the board.
I ordered some 1/2" MDF, hoping by the time I machine both sides of that I will get better results. Was not sure if anyone used a different material that allowed more air flow or not.
knowlzy0791
Re: Surface Board
Postby Rcnewcomb » Mon Feb 29, 2016 11:01 pm
This discussion of vacuum plenums over on the ShopBot forum might be of interest to you: ->Link
Re: Surface Board
Postby knowlzy0791 » Tue Mar 08, 2016 9:31 pm
Dropped down to 1/2" board, then surfaced both sides bringing it to roughly .45"
My suction has almost doubled.
knowlzy0791
Re: Surface Board
Postby gbradley » Fri Apr 08, 2016 6:39 pm
What type of machine do you have? What is the vacuum table made out of? What kind of HP is the blower you have?
gbradley
Model of CNC Machine: A red one
