I would like to see some texture examples
- FixitMike
along with the parameters entered to achieve the texture and the tool used. Also some examples from the Texture Gadget.
- Model of CNC Machine: ShopBot PRS 96x48
Re: I would like to see some texture examples
Here is a very simple sign I made on my first attempt at using texturing. I used a 1/8" ball nose bit at a feed rate of 2.5"/sec and an RPM of 12000.
Almost forgot:
max cut depth is 0.1"
max cut length is 1.5"
max overlap % is 20
step over = 0.118"
angle = 0
max overlap % is 20
step over = 0.118"
angle = 0
- Model of CNC Machine: FLA Saturn 4x4 / 7W & 60W lasers
Nice looking texture. Thanks for the details.
Did you do an offset around the text? It looks like it goes right up to the text.
Dave
https://lakesedgewoodcraft.com/
My apologies - yes, I used an offset of 0.125" which I believe applies to all boundaries for the textured tool path.
Charlie
Charlie
In corian, mcd .1, McL 058 m.o.30% step .1181, angle 0 offset .125
1/4"ballnose
1/4"ballnose
