I'm looking for those masking sheets they're like giant sheets of masking tape. You can put them on your work, do a V-carve without them peeling away, and then you can paint down into the carving before peeling it off. They come in clear or different colors and in different strengths.
I found them at staples online once (but not in their store), but now they've changed their website and I'm tired of going in circles with their @#$^ search function.
Can someone please tell me the correct name of this stuff? Please?
And if you're in a real festive holiday mood maybe you could include a link to some website with a user-friendly interface where I could find it fairly easily?
thanks...
What's the real name for that masking stuff?
Re: What's the real name for that masking stuff?
I'm not real sure of the physical description of what you are wanting; but, I searched Staples for "Masking Sheets", and it found: "S&S Sticky-back Foam Sheets". Not sure what they mean by 'foam' but they don't look real thick. Nine by twelve-inch sheets; not sure if that is 'Giant' but certainly larger than typical masking tape.
If you go to 'S&SWW.com' and search for "Masking Sheets", you get the same product. $5 for a pack of 10 sheets -- plus shipping, of course -- Maybe Staples has them in stock. But, wouldn't cost much to get some and see if they work.
rf
rf
- Model of CNC Machine: Shop-Made Router
Thanks, but that's not it. Those are thin little sheets of colored foam with adhesive on the back. The stuff I'm looking for is a very thin plastic with a releasable adhesive on it.rayray wrote:..., I searched Staples for "Masking Sheets", and it found: "S&S Sticky-back Foam Sheets". Not sure what they mean by 'foam' but they don't look real thick. ...
rf
- Model of CNC Machine: Stinger 1 and Mabel, both with 4 axis
They are usually called vinyl paint mask or sign mask. Two of the brands are Avery and Oracal. I got mine from a local sign supply shop.
Thanks! That's it.eph210 wrote:They are usually called vinyl paint mask or sign mask. Two of the brands are Avery and Oracal. I got mine from a local sign supply shop.
- ChrisInEstes
- Model of CNC Machine: Vytek 4' X 8' - Perske Spindle - Mach3
I Use Pask brand vinyl paint mask, and I get it from Fellers. It's as good as the Avery, 3M, Oracal, & Gerber paint masks I've used, and cost's less. I buy 15" wide 50 yard rolls for (I think) $75 plus shipping.
Chris
Chris
- Model of CNC Machine: FLA Saturn 4x4 / 7W & 60W lasers
Does this paint mask machine cleanly? Obviously you need to use sharp tooling. Just wondered if the edges are clean and crisp after painting.
Dave
https://lakesedgewoodcraft.com/
Only time I have had a problem was when it was way to cold in the unit, my own fault for not putting the heater on. Vinyl can become quite brittle when it gets cold. Had it shatter on me while cutting which left jagged edges. Not a big problem though, warmed the unit up a bit, removed the paint mask, applied another bit & re ran the toolpath.
Paint mask is available in different tac's (degrees of stickyness) most of the signmaking suppliers will send you out a small sample so I would contact them & ask for a sample of each so you can try it before committing yourself to buy.
I also use sand blast vinyl for my blast cabinet, that cuts well on the plotter so no reason why it shouldn't work on a router either although I have never actually tried it.
I have been using Transfer Rite Ultra.
A friend with a Graphics Shop gives me the ends of rolls.
It is Vinyl Letter transfer tape, but it works great for masking and then cutting on my ShopBot.
It is very thin and somewhat brittle.
The surface needs to be very smooth. I generally block sand painted surfaces prior to taping.
No tear out at all with down cut bits and sharp v-cutting bits.
Up cut bits tend to leave a rough edge.
I also use it for making signs with the laser.
Stick it down to the back of a sheet of acrylic, reverse cut the letters with a weak laser beam to just cut through the transfer tape, weed out he letters and spray paint. After the paint dries, pull off the tape and the sign is complete.
Dennis
Dennis
I have used Con-Tact brand Contact paper you can get it in clear or white, and it is pretty cheap, comes in a roll 18" wide, seems to work well for me but I sure would be open to other ideas on what would be better
Thanks Don
Thanks Don
Have a Great Day Making Chips
Don
Don
