Height of ToolPath toolbar
- Model of CNC Machine: PAE 110SD Series/Mach3 Software
Hey everyone,
This is being extremely nit-picky, but is there a way to shorten the height of the toolpathing toolbar? Right now to hit "calculate" or "cancel" I have to scroll down a little bit, but I can't use my mouse wheel because that just makes me zoom out on my drawing.
Even if I can un-pin something like "last pass" box for the time being. I don't do anything intricate enough to use this feature anyway.
Thanks!
Thanks!
- Model of CNC Machine: Home built cnc router using Masso G3.
Re: Height of ToolPath toolbar
I had a similar issue, in that I couldn't view the job diamensions that appear in the lower left corner of Aspire.
The fix for me was to move my windows task bar from the bottom of my computer screen and have it up the side of the screen.
That allowed Aspire to fill the bottom part of the screen and I could then view the job diamensions.
You could also find the setting to "Auto Hide Task Bar" and see if that works.
- Ms Wolffie
Even with the Taskbar hidden, I have the same problem.
It is very annoying and a waste of time.
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- Model of CNC Machine: EZ-Router
If I understand your dilemma correctly – your “calculate” and “close” buttons are not visible?
Maybe it has to do with screen resolution.
Even with “Show advanced toolpath options” checked, I still have some “free space” at the bottom.
See picture attached.
- Ms Wolffie
No, it has nothing to do with screen resolution.
I have a touch screen but Aspire cannot be sized with touch.
It is only 2D profile that I have a problem with.
Too much content makes it too tall for my 26" screen.
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
Even with 2D profiles it makes no difference, still some space at the bottom.Ms Wolffie wrote:It is only 2D profile that I have a problem with.
Is the Aspire window maximised? I can size Aspire on my touch screen ok, using the normal drag handles on the corners of the windows but I generally run with it maximized.
To get an advanced toolpath tab showing without scrollbars the window has to be around 1000 or so pixels tall.
- Ms Wolffie
Yes, mine is maximized and the screen resolution is 1920 x 1080 so definitely large enough.
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
Standard font size?
What version of Windows are you running? The top of your screenshot looks a bit strange.
- Ms Wolffie
Windows 10.something
What do you mean "strange"?
It is a cropping of a screenshot and purely toolpath.
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
There's a lot of white space above the toolpath header. Might just be the theme you're using.
Mine looks like the attached for example in Windows 10 at 1920x1200 resolution with standard fonts and the Aspire window maximised.
I run dual monitors so there is no windows task bar on my drawing screen, and it does stretch all the way to the bottom, completely maxed. I run Windows 7 or something or another lol.
As you can see in Ms. Wolffie's screenshots, I have the exact screen as her. It is so close it's aggravating
So I suppose if someone winds up finding a solution please post it!
No-one has replied as to which font size they're using yet though. I can't see what else it could be, unless I'm missing something obvious, if the resolution is more than a 1000 pixels etc. Even with the large Windows 10 taskbar across both of my monitors it fits with plenty of spare room.
If you don't use the advanced toolpath features then unchecking "show advanced toolpath operations" will shorten the dialog considerably.
I can't believe I didn't see that. That is literally what I wanted to do lol
What a dummy
What a dummy
I had the same issue as Ms Wolffie and others. Running Windows 10.Adrian wrote:Standard font size?
Resolution 1920 x 1080
The display settings were set at default of 125%. If this is changed to 100% then entire toolbar can be seen, but awful small. I think it turns out to about 7.2 font, based on assumption of default font size of 9. Note the options for the settings are in 25% increments. I think this is a font size of 9 (per default setting in advanced display settings)
I changed all shown below to font size of 8 and entire toolbar can be seen. I kept this setting.
