Evenly spaced objects
I know this is so simple....I need a series of 16 holes machined in a line 1/2 inch apart. How do I make the holes have even space between them without all the measuring and setting the helper lines? There has to be an easier way.....
- Model of CNC Machine: homebuild / VCP 8.0
Re: Evenly spaced objects
You can create one circle desired size and use the linear array tool, just specify .500 offset X-Y and quantity in either rows or columns depending the orientation you wish.Dash66 wrote:I know this is so simple....I need a series of 16 holes machined in a line 1/2 inch apart. How do I make the holes have even space between them without all the measuring and setting the helper lines? There has to be an easier way.....
Thank you so much!! I have been busy with other things and havent even started my machine in 6 months.....Big investment just to sit... Seems I have forgot a lot of the simple things.....Thanks again!!
Dash
Dash
