Good morning,
I have a question about VCarve Pro, I want a picture with signs of rope milling around.
When I edit a photo in PhotoVcarve and have saved as a photo ....... files (* Pvc).
And go to VCarve pro, create a new file, via Clipart ----- rope border with Knote.
Through Toolpath 3D Rough / Finish and if this is done I am going to create 3D Models vector bounary. I milling this material, if this is done I go back to Drawing tap and load the photo and place it in the middle. And go back to,
Toophaths, go to Prieview Visible Tool Paths, I see no picture.
What am I doing wrong?
load a photo with a border
- Model of CNC Machine: Emach EM900. KEW 1212
Re: load a photo with a border
I suggest that the original picture needs to be saved in a format that V Carve will recognise such as BMP, JPEG etc.
Then import the picture into V Carve directly then plan the cut in there
If you can't fix it with a hammer you've got an electrical problem !
