v carve inlay using v carve pro 8
- Model of CNC Machine: Thermwood cabinet shop 43 atc
Working on my first inlay and the pocket looks great . When I made the inlay the smallest size is the same as the pockets opening and gets larger any ideas on what I did wrong?? I read on one set of instructions that said to turn vectors on when you tool path the inlay but I don't see that option anywhere. Please help
Re: v carve inlay using v carve pro 8
Did you specify an offset on the inlay? If so did you get it the wrong way around perhaps?
You'll need some sort of offset on the inlay/pocket to get it to fit. Exactly how much depends on many factors so it's really a case of experimentation.
I am using the v carve /engraving toolpath as per directions for v - inlays no where do I see direction or place for offset
- Model of CNC Machine: Stinger 1 and Mabel, both with 4 axis
Using the V inlay technique, you need to set a start depth for the inlay side. This start depth is the part of the inlay that goes into the pocket. Set the start depth a little smaller than your pocket flat depth so that it doesn't bottom out in the pocket.
Euan
Euan
Thought you were doing a normal inlay. The V-inlay is a different process. Follow the instructions and you should be fine. I haven't done one for a couple of years but it all worked as per the instructions when I did. Make sure you put all the values such as the start depth in. It's easy to miss that one.tnorthrop wrote:I am using the v carve /engraving toolpath as per directions for v - inlays no where do I see direction or place for offset
