toolpath startpoints
I am cutting 1/4" UHMW. The drawing was made in Design CAD 3D Max and imported to V Carve Pro. The Perimeter is 200" and there are 10 indentations on each of the two long sides. The toolpath cuts in one direction but the path jumps across the part to start points at some of the indentation. It is adding a minute plus to the cut. Can I delete the start points and have the cut run continous around the part? I have tried the differant orders - grid and shortest path have worked the best. Attachedpic shows the tool path crossing the part.
- Model of CNC Machine: Shop-Made Router
Re: toolpath startpoints
There is only one start point for each vector. If you have more than one, then it could be that your shape is created from a bunch of different vectors. In V-Carve you can highlight all the vectors in that shape and join them together. That will create one path with one start point.
- FixitMike
Using a ramp and/or a lead in the Profile tool path will reduce or eliminate the plunge marks. Also, with VCarve Pro 8, they have added the option for a separate full depth last pass to clean up.
They will all add some time for the cut, of course.
