Make grid for spoil board in V Carve Pro
Slab
Model of CNC Machine: Laguna 24x36 HHC IQ
Post by Slab »
I just purchased a Laguna IQ with the V Carve software.
Is there a easy way to make lines that are straight both vertically and horizontally in exact 1 inch segments? (This would I've me a grid pattern) By doing this is would give me a better way to lay out my work on the spoil board without guessing.
Thank you
Alan Male
Model of CNC Machine: heiz 400T
Re: Make grid for spoil board in V Carve Pro
Post by Alan Male »
Create one vertical line to represent the left hand edge and one horizontal line for the bottom edge.
Then use 'array copy' using the vertical line with copies in the 'X' direction.
Then use 'array copy' using the horizontal line with copies in the 'Y' direction.
However, if you're really stuck, give me details of your spoil board size and I'll create a file for you.
Cheers,
Alan
CNC m/c - Heiz 400T
Software - Aspire, VCarve Pro, Photo VCarve, WinPC-NC
CAD - Catia V5
Alan Male
Post by Alan Male »
...and just in case it's 36" x 24" here's a file.
SpoilboardGrid_36x24.crv
(25 KiB) Downloaded 1414 times
Cheers,
Alan
CNC m/c - Heiz 400T
CAD - Catia V5
dhellew2
Model of CNC Machine: Legacy Artisan 72 and AVID CNC Rotary
Post by dhellew2 »
When you do an array don't forget to check gap [distance between] or offset [center to center]
Dale
Young = time, no money
Old = money, no time
Dale
DocRock
Model of CNC Machine: SmartShop II 5x10
Post by DocRock »
When I try to carve this I get errors because all vectors are open. Please advise
Alan Male wrote:...and just in case it's 36" x 24" here's a file.
Cheers,
Alan
scottp55
Model of CNC Machine: ShopbotDesktop 5.5"Z/spindle/VCP11.5
Post by scottp55 »
Do it as a Profile cut, On the Line?
Not looking at the file though.
On mine,I copy every 6" line onto another layer, and cut twice the depth so it's easy too see at a glance where I am without counting the lines :)
Also good as they're still visible after surfacing the inch marks off.
R.N.
edwan
Model of CNC Machine: Shapeoko
Post by edwan »
What Scott said. Do it as a profile. Define the origin and area(and the bit in tools of course). Set the steep over. I use a raster cut at a fairly high feed speed.
edwan
Post by edwan »
Opps! I should have said, "Do it as a POCKET". Define the origin and area(and the bit in tools of course). Set the steep over. I use a raster cut at a fairly high feed speed.
This way there are no lines to draw and nothing to calculate.
