Excel feed and speeds spreadsheet.
- FixitMike
I made the attached spreadsheet to make a reference for setting my router speeds. I believe it is more convenient to use than most charts. It is designed for my machine, which has a maximum feed of 100 inches per minute, and a speed range of 5,000 to 25,000 rpm. It can, of course, be modified to suit your machine.
The file is zipped, because this forum will not accept .xls files.Good judgement comes from experience.
- Mike-S
Re: Excel feed and speeds spreadsheet.
Thanks, Mike--nice tool to have.
- Model of CNC Machine: CNC6040
I have downloaded it but not had a chance to look at it yet. but here is a big thanks in advance
Ian
Ian
I know pass depth should change the outcome, but don't see it in your calculations. What pass depth does your table assume?
- Model of CNC Machine: XYZ Gantry, PMDX motion, Mach3
Thanks Mike ! Should come in handy.
- FixitMike
The assumed pass depth is equal to the tool diameter.
Amana Tool suggests if it is 2 x Dia, reduce chip load by 25%, and if it is 3 x Diameter reduce chip load by 50%.
- dhellew2
Thanks Mike.
Nothing wrong with pdf's
Dale
Dale
Young = time, no money
Old = money, no time
Dale
Dale
- FixitMike
Dale: Can PDFs work like a spreadsheet? For example, if you change the inches per minute number, the RPMs will change in the chart to suit.
- Ms Wolffie
Yes, provided you have Adobe Acrobat and make it editable.FixitMike wrote:Dale: Can PDFs work like a spreadsheet? For example, if you change the inches per minute number, the RPMs will change in the chart to suit.
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- FixitMike
Wolfie: Do PDFs do the calculations for you? In my spreadsheet, if you change the feed number, all of the speeds are automatically recalculated for you. The cells have the formulas entered.
You could put it on Google Sheets if it being in Excel format is a problem for people.
- Model of CNC Machine: Shark Piranha
Thanks Mike, I downloaded it and it went right into Numbers (Xcel for us Mac users!) Works great,
Mike
Mike
FixitMike wrote:I made the attached spreadsheet to make a reference for setting my router speeds. I believe it is more convenient to use than most charts. It is designed for my machine, which has a maximum feed of 100 inches per minute, and a speed range of 5,000 to 25,000 rpm. It can, of course, be modified to suit your machine.The file is zipped, because this forum will not accept .xls files.
- Ms Wolffie
If you use AA it will import the spreadsheet exactly as it is formulated including formulas (bad English?)FixitMike wrote:Wolfie: Do PDFs do the calculations for you? In my spreadsheet, if you change the feed number, all of the speeds are automatically recalculated for you. The cells have the formulas entered.
But the PDF must be made open for editing, you cannot have your cake and eat it too
Meaning that people who use it will be able to alter it.
After a rethink, I saw another solution, if people import the spreadsheet, I believe they can post it into Excel. If you place the formulas into a separate cel as an entry, they should be able to copy and paste into the top row.
I will have a look at it tomorrow a bit late here now.
I believe numbers are only in Windows 8.
Still thinking
If you upload the spreadsheet into Dropbox, they can download it as is into Excel
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- Ms Wolffie
https://www.dropbox.com/s/1q4zm7eodvehe ... r.xls?dl=0
I just put it into my dropbox and all people have to do is tell it to open it in Excel
Very very short, sharp and shiny that dropbox
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- Model of CNC Machine: Home built designs - 3'x4' and 5'x12'
The file opens into Apache Open Office Calc v4.1 just fine. It's a free download office suite. I also added a text note in my copy of the spreadsheet file that shows your comment about the pass depth.
Thanks Mike,
CarveOne
Thanks Mike,
CarveOne
CarveOne
