Fed up with constantly undoing allen key bolts or wingnuts on the extraction every time you change a bit?
I purchased 10 neodymium magnets(10mm x 5mm) from ebay for £3. Mounted 4 off them in the extract mount(using just a press fit) and epoxied another 4 to the router holder. Their is a .5mm gap between the magnets so they don't lose attraction by crashing into each other. These are EXTREMELY strong magnets and have given no problems. I can now take the extraction off/on in seconds.
Quick Release Extraction
Re: Quick Release Extraction
Good idea bigz ThanksbigZ wrote:Fed up with constantly undoing allen key bolts or wingnuts on the extraction every time you change a bit?
Bruno T of Edmundston
- Thkoutsidthebox
