Flattening spoil board.
Postby SIBUD » Tue Feb 19, 2013 9:20 pm
So later on today the mailman will bring the large diameter bit I will use to flatten my spoil board.
So I assume one makes very shallow cuts while having the bit move back and forth with some overlap between passes?
Is there a standard routine somewhere that I could use and just change the parameters for my bed size?
Any info appreciated.
Bud Meade
Nashville, IL
I don't own too many BMW motorcycles, I just have too little time.
SIBUD
Model of CNC Machine: Signal Seeker 24X24
Re: Flattening spoil board.
Postby Adrian » Tue Feb 19, 2013 9:36 pm
I do it by drawing a rectangle the size of my table plus the diameter of the bit (that bit depends on whether you have open ends and/or sides on the table) and create a pocket toolpath with the raster option set.
Some control software (like the Shopbot one) have routines that do spoil board surfacing as well.
Postby SIBUD » Tue Feb 19, 2013 10:09 pm
Adrian wrote:I do it by drawing a rectangle the size of my table plus the diameter of the bit (that bit depends on whether you have open ends and/or sides on the table) and create a pocket toolpath with the raster option set.
easy peasy! Thanks.
Bud Meade
Nashville, IL
SIBUD
Postby tmerrill » Tue Feb 19, 2013 10:46 pm
I suggest you use a ramped entry with a bit like that.
The pocket toolpath offers the option for Ramp Plunge moves which is perfect for that application.
Tim
tmerrill
Postby SIBUD » Wed Feb 20, 2013 2:28 am
tmerrill wrote:I suggest you use a ramped entry with a bit like that.
Tim
Thanks for the tip Tim. What cutting depth would you recommend for my first pass with the bit zeroed to the top? I was thinking very shallow for first cut to see how close it is. If it cuts all the way across the spoil board, then I wouldn't have to take off any extra. If the first pass left areas untouched, I could run it again a little deeper.
Are there any other parameters that would have to be set with a ramp plunge move?
Appreciate all advice.
Bud Meade
Nashville, IL
SIBUD
Postby bbiehl » Wed Feb 20, 2013 6:27 am
I recently got a 2-1/2" spoilboard cutter (Amana) to flatten my workpiece. The first time I used it I tried going down .06" at 10ips and the cutter stalled (I have a 3hp water cooled spindle). I now go down .03"/pass at 5 ips and it seems to work ok ( I also overlap 50% at 12000rpm). Ramping is a good idea, I will also do that in the future.
-brian
bbiehl
Model of CNC Machine: Legacy Arty 58; Aspire 9.5
Postby Rcnewcomb » Wed Feb 20, 2013 7:19 am
I agree, 0.03" is a good starting point.
Postby Mike-S » Wed Feb 20, 2013 8:10 am
Why don't you manually jog around the bed and touch-off the bit in a number of places? Check the DRO to find the max high and low. Then set up you surfacing cut from that info.
Mike-S
Postby fixtureman » Wed Feb 20, 2013 12:59 pm
I only cut it .010 the first time on a new spoil board then .005 when needed. This on a 48x96 table.
fixtureman
Postby SIBUD » Wed Feb 20, 2013 1:42 pm
Thanks for all the suggestions. :mrgreen:
Bud Meade
Nashville, IL
SIBUD
Postby Eddiem » Thu Feb 21, 2013 2:29 am
I did mine by using my keyboard and running the bit back and forth myself that way i was able to go right to the edge of my cutting area for my cnc it did not take to long but made a big mess as i did it with no dust foot on so i could see what i was doing..
Maybe not the best way to do it. LOL
Eddiem
Model of CNC Machine: Romaxx WD-1 and cuttom built 24x48 CNC
Postby fixtureman » Thu Feb 21, 2013 10:05 pm
You can draw your pocket just a little larger than your table and it will surface it to the edges.
fixtureman
Postby Lazerbee » Sat May 04, 2013 4:05 am
Why not cut an X and Y straightedge into the spoil board during the flattening process?
Lazerbee
Model of CNC Machine: Vytek 3624, Mach 3 Plasma, Mach 3 Router
Postby irishwoodworker » Mon Nov 05, 2018 2:09 pm
A great idea, Lazerbee. I did mine after flattening and should have done both together. I also made two MDF fences, one for each axis. Each has a dead straight bottom strip (screwed to the fence (top)) part that rides against the indexed ends/sides of the spoil board. I drilled two holes at the appropriate places and attached two closet bolts to hold in place. I did not worry too much about getting the fence part (top) square ahead of time and just ran a 5mm cutter along each axis to square them up after snugging up to the spoil board. I used Peter Pasuello's great wingnuts (https://www.dropbox.com/sh/h8qjq6fxnpe4 ... 1oTf7-gm3a) although I believe Peter credits another CNC maker for the original idea.
irishwoodworker
Model of CNC Machine: Axiom Pro+ 8
