Is their a way to Mirror a 3d file
rjgodboout
Model of CNC Machine: Laguna IQ 24 x 36
Post by rjgodboout »
I am ready to cave an image on a double door cabinet. My neighbor would like a left and right leaning bear hugging a girl, STL file.
Is this possible. If so how??? I've only had my machine for a few months and I"m pretty impressed. I've learned to be careful with the software as it can bite you.
Thanks, Bob G
Port Charlotte Fl
Re: Is their a way to Mirror a 3d file
Post by highpockets »
Select the model and use the Mirror Tool on the Model Tab.
gkas
Post by gkas »
The mirror tool is only available for 3D stl in Aspire, not Vcarve. Vcarve will not mirror the stl. Following the one stl in Vcarve rule?
gkas wrote:The mirror tool is only available for 3D stl in Aspire, not Vcarve. Vcarve will not mirror the stl. Following the one stl in Vcarve rule?
Works ok for me in VCarve. The mirror tool is on the drawing tab not the Modelling tab and will mirror an STL.
Post by mtylerfl »
gkas wrote:...Following the one stl in Vcarve rule?
You can have as many duplicates of that one STL file in VCarve as you want. Mirrored, resized, rotated, arranged - whatever.
gkas
Post by gkas »
Good to know. I saw that Aspire had a mirror tab in modeling, but Vcarve didn't. I ASSumed that the Vcarve one wouldn't mirror stl. My mistake.
Post by mtylerfl »
Here's an example of an imported (and duplicated) STL model into VCarve. Piggies galore!
Post by mtylerfl »
gkas wrote:Good to know. I saw that Aspire had a mirror tab in modeling, but Vcarve didn't...
To Mirror QUICKLY:
1) Select the model
2) Press Ctrl+Shift+H to mirror/duplicate horizontally
3) Press Ctrl+Shift+V to mirror/duplicate vertically
(To mirror anything without duplicating - select any item and just press H or V)
rjgodboout
highpockets wrote:Select the model and use the Mirror Tool on the Model Tab.
Highpockets, Thank you.
Yes you can mirror in VcarvePro 9.0
RJG
