The "Ultimate Tabletop Machine" for Woodworkers
Re: The "Ultimate Tabletop Machine" for Woodworkers
Postby IslaWW » Tue Feb 06, 2018 11:11 pm
Send me an email... in my signature lower left of any of my posts
CNC Technology & Training
IslaWW
Postby IslaWW » Mon Feb 12, 2018 1:23 am
Someone must have thought of another option to add by now?????
IslaWW
Postby Rcnewcomb » Mon Feb 12, 2018 6:28 am
I can see strengths and limitations of of either an on-the-table or a beside-the-table 4th axis.
On-the-table would require more Z clearance which introduces rigidity problems for the Z axis, but reduces the space needed for the machine in the X or Y dimension.
Beside-the-table requires extra desk or floor space for the machine, but does not require the extra Z height. I guess my preference would be for this arrangement, but I am open to either option.
Are there control systems that can recognize if/when steps are lost and then reorient itself to a known position before it starts cutting again?
An ultimate machine would never need maintenance, or at least be self-lubricating and self-cleaning. It would keep track of hours and play in the system and let me know when and which parts need replacing.
How about an optional air drill or laser that could rotate 90 degrees to drill holes either from the top or on the sides of material...
Postby 4DThinker » Mon Feb 12, 2018 1:36 pm
Another option? How about using the extra heat created during a cut to keep my coffee warm? ;)
4DThinker
Postby ger21 » Mon Feb 12, 2018 2:26 pm
You can add encoders to your steppers, and monitor and compare the encoder position to the commanded position. If they differ, then you stop the machine, and re-home it. You can do this with a few of the hobby controls, with a little programming.
ger21
Postby Leo » Mon Feb 12, 2018 5:40 pm
Do we need Heidenhein Glass Scales
Just thinking accuracy here. :lol: :lol:
https://www.google.com/search?q=heidenh ... 28&bih=720
www.leosworkshop.com
Leo
Postby IslaWW » Mon Feb 12, 2018 9:32 pm
Leo...
Love your sense of humor!!
Of course we do. But the labor to calibrate them on machines with .002" (at best by their own admission) no load positional accuracy to be used by operators with usually .010-.015 accuracy on material that will most likely move .010-.020 after cutting will be expensive!
IslaWW
Postby Rcnewcomb » Tue Feb 13, 2018 1:43 am
Is it a sign that I'm a nerd because I was reading up on linear encoders earlier this week?
Postby IslaWW » Tue Feb 13, 2018 3:00 am
Randall...
A clear and obvious sign! Step away from the internet! :D
IslaWW
Postby TSM2018 » Fri Apr 13, 2018 6:12 am
I'm probably not at the apprentice level in 3 months, but I would ask for 5 gantry(s) and (5) routers. Automatic tool changes are way too much money, Taig Tools has the concept for their CNC lathe. (I have a Taig CNC Mill)
I know how much a router costs; I would just need a longer bed to park the other gantry(s) when not in use. You have a much smoother flow of machining time without tool changes, and my lazy attitude about tool bit changes improves my designs. I want credit for the concept and get first dibs on testing. We can let Vectric be first to program.
No time to file a utility patent if someone else hasn't already done this. If you make a million bucks on this, I'll send you my address and you can send me a machine to play with.
If I'm not first for concept to post, then shoot me down tomorrow. I'll be at the USER Group Meeting in 2018... Leo is probably going to tell me I'm too late.
Cheers!
TSM2018
Model of CNC Machine: DWC2440, Taig CNC Mill
Postby Leo » Fri Apr 13, 2018 1:10 pm
What about linear motors
I am sure we can get a 24 x 36 machine to cost $75,682.56 - Base price
Leo
Postby Leo » Fri Apr 13, 2018 1:15 pm
IslaWW wrote:Leo...
I have not looked it up but I am pretty sure the glass scales are better than .002
I can position my grinder to .000010 (10 millionths) with glass scales
Leo
Postby IslaWW » Fri Apr 13, 2018 1:49 pm
Leo...
That is a lot tighter tolerance than I could ever achieve. I will have to live with a few thousandths that I can get off a router.
The list of options really did well on a parallel thread on Sawmill Creek forum: https://sawmillcreek.org/showthread.php ... oodworkers
80 replies and over 5000 views. Instead of a tabletop, which would limit features, especially number of tools in the rack and ability to install a vertical machining plate at the front of the machine for end mortising, etc., I opted for a heavy duty floor standing model. This should be a very nice package for luthiers, discriminating hobbyists and pro users that can take advantage of a small footprint. ATC spindle is standard
IslaWW
Postby LittleGreyMan » Fri Apr 13, 2018 2:30 pm
Gary,
Your choice makes sense. A rigid CNC of this size can in fact no more be called a tabletop as it requires a dedicated cabinet. So making the step for a floor standing model sounds natural.
You'll have a marketing issue: catching attention of people searching for a tabletop machine before they realize this.
Best regards
Didier
W7 - Aspire 8.517
LittleGreyMan
Postby IslaWW » Fri Apr 13, 2018 3:13 pm
LGM...
Thanks for the words of advice. If required, marketing will mention "The Ultimate Woodworkers Machine", eliminating the "tabletop" verbiage. This may not be relevant as most of this years frame production has been presold and I have had to increase the original order size in order to have one for myself.
IslaWW
PreviousNext
