Oh, One other trick from TJ at Shopbot class during the unfilmed QA sessions afterwards(class is free for all CNC people)
Try selecting multiple nodes and then hold down "V"(for vertical) or "H" horizontal, and then play with your nudge arrows:)
It's kinda cool:)
Node editing
- scottp55
Re: Node editing
- scottp55
Re: Node editing
Oh, Just noticed in the news letter that Vectric has a few of the very short "Tips and Tricks" out that James has mentioned.
4 of them are Node Editing:)
http://support.vectric.com/tips-and-tricks/select.php
- JamesB
- Vectric Alumni
Re: Node editing
Thanks for noticing Scott. There are only a small selection of videos at the moment and one those was re-purposed from the User Group. We are aiming to keep adding to these though particularly once we're settled into our new offices later this month...
Cheers,
James
Cheers,
James
- scottp55
Re: Node editing
Really like the additional approach of subject specific short tutorials James!!
Sometimes searching for the one shortcut you need can take hours(NOT that it's time wasted as always learn Something).
Stuck it on the 'Bot forum and already had a thank you, although it should REALLY go to you guys!!
Who was the "Node Edit" Lady....really nice to stick names to voices.
Humble thanks to Vectric Team,
- Makingtoothpicks
- Model of CNC Machine: Cncrouterparts CPR2448
Re: Node editing
I also agree that the short to the point tutorials are great and a time saver. You still need to take the time and work through the full versions.
Don
Don
- Vectric Staff
- Model of CNC Machine: Various
Re: Node editing
Hello Scott,
The "Node Edit Lady" is me, Beki. Thank you for your comments, and as James has stated we will aim to add more short Tips and Tricks videos later this month. Any suggestions for short videos can be e-mailed to online@vectric.com
Thanks.
Thanks.
Beki
- scottp55
Re: Node editing
Hi Beki,
Nice to "meet " you....I keep seeing your name in things, but now have voice to go with the name
Very well done!
Very well done!
- Model of CNC Machine: Solsylva home built 24x48
Re: Node editing
Some of the signs I do people send me a photo or drawing they get off the internet that are just a mess. This will speed things up considerably.stanv77 wrote:Hello
If you fit curves to selected vectors(which is in the edit objects section) and check Bezier. This will reduce the number of nodes.
from there you edit or move each the way you want. If you have trouble let me know and I can try to clean it up for you.
Mike kearns
noveltysigncarver.com
