Cooler than sliced Bread
ssflyer
Model of CNC Machine: ShopBot PRSAlpha 96x60
Re: Cooler than sliced Bread
Post by ssflyer »
Hmm - one more quick question - do you leave the paper mask on when cutting, or take it off, first? :oops:
Ron Sloan
sawmiller
Model of CNC Machine: joe's rack and pinion hybrid
Post by sawmiller »
leave it on, you dont need to go that deep, only go 1/3 of the thickness or so
In the heart of Tn
jmkissell
Post by jmkissell »
Thanks for the info and inspiration. I gave it a try and it turned out fantastic!
fretsman68
Post by fretsman68 »
It sure did! Nice work!
Dave
Dave
sawmiller
Post by sawmiller »
now you need to cut something like this,
placing the leds in the edge of the pocketed area.
then the plexi,
viewing will be from the other side.
In the heart of Tn
MikeUSNRet
Post by MikeUSNRet »
Running into a bit of a snag here.
trying to cut a sign in a .25 piece of plexi using a .25 dia 120 deg v bit to a flat depth of .125 using .060 per pass, but it seems that regardless of what speeds and feeds combo I try, am getting quite a bit of melting :(
Any suggestions? carving too deep? angle of bit too large?
help!!!
Note..using VCP here..don't have aspire (Yet)
Mike
STGC(SW/AW) M. Wenman USN Ret.
1982 - 2005
sawmiller
Post by sawmiller »
dont go so deep. they have people on the intrent that are scratchin plastic with a nail, and getting it to work
i havent used that wide of a angle bit , either
also you can slow down the rpm as much as possible, put a thin layer of water/dishsoap on the surface to help cool the bit.
In the heart of Tn
MikeUSNRet
Changed from a .25 dia 120 Deg to a .25 dia 60 deg bit. changed the depth from .125 to .08333 (1/3 the material thickness - .25 plexi) and ran again at 10k rpm router speed at 40ipm. still got quite a bit of melting. Logged back on here and saw your water/soap suggestion sawmill so put some of that on the cut and am running it again. Thanks for the tip. didn't think of cooling the bit and it is a simple oversight, but should have a clean cut now with just a plastic slurry to hose off :)
Don't have any LED's yet, but just wanted to get my feet wet so to speak so I know what to do/don't do when I get back from my vacation (going to Minneapolis area 3rd & 4th).
thanks again
Mike
1982 - 2005
ssflyer
Post by ssflyer »
I was getting quite a bit of melting, until I dropped my RPM's down to ~7-8K....
Ron Sloan
jhegel
Post by jhegel »
Here is a supplier for 12v wall warts, or anything else electronic.
http://mouser.com/Power/Plug-In-AC-Adap ... 1gZ1z0wdi9
jmkissell
Post by jmkissell »
Finally got the frame done for the praying hands.
As usual I would do a few things differently.
Next time I think make a thicker frame and put the LED's in the wood not the Plexiglass.
wcarrothers
Post by wcarrothers »
hehe. I found it interesting how similar your bases (Passuello) were to the one/design I came up with to make this batch back in dec 2009 jan 2010..
See pic Image
Only thing missing in this pic were the white screws on either side (they were not in on this prototype)
Also used Sintra Plastic rather then wood..
b.
jmkissell
Post by jmkissell »
Very Nice, did you have to do any special finishing on the exposed edges?
P.Passuello
Model of CNC Machine: Joe's Hybrid
Post by P.Passuello »
wcarrothers wrote:hehe. I found it interesting how similar your bases (Passuello) were to the one/design I came up with to make this batch back in dec 2009 jan 2010..
b.
Hi William,
They are very similar but I assume you started your design from the same point that I did, the LED strip and worked from there. The number of options for the basic base is probably limited but I do like the hidden screws for the top piece if indeed there are any at all.
Even stranger is the time frame as we must have designed them at about the same time as I made the Santa in time for Christmas 2009
Was your one used as a trophy for a TV Program? I see in New Zealand there is a 'Dancing with the Stars on Ice' tv program currently playing.
But the prize in my opinion goes to jmkissell for his praying hands in the round base.
That is an amazing piece of work and I can't help wondering what the combination of his frame and my clock would look like together, I think it would be cool. 8)
Cheers
Peter
The ingenuity of idiots is unlimited.
http://www.youtube.com/user/cncnutz
ssflyer
Post by ssflyer »
OK, these don't really compare to some of the others, but I gave it a try - sorry for the poor pictures...
Ron
Ron Sloan
