Cooler than sliced Bread
- Model of CNC Machine: Camaster Panther 4x8
Re: Cooler than sliced Bread
Do you flame polish anything when you do 3d?
Thanks everyone. As for flame polishing after cutting, I don't. I have tried flame polishing the edges but I just end up melting the acyrlic.
- zeeway
That looks very good, Doug. I will bet your pastor is thrilled.
Angie
Angie
- Model of CNC Machine: Shark Mako HD
Can the Last supper be done with Vcarve pro? or can it be done only with Aspire?
- Model of CNC Machine: Home built jgro
Hello all.
First post on this forum.
Ref V Carve and the Last supper, yes.
Here is a V Carve file that I found on another site.
Hope it works for you.
- last_supper.zip
- (1.39 MiB) Downloaded 396 times
Here is my first attempt at an edge lit sign.
I have learned a bit about led's and resistors since.
- Model of CNC Machine: Digital Tool CNC Router + Speedy 400 120
i can't wait to get Aspire and try making some of these.
i want to make back plates for my each of my stairs with words and/or designs and top edge light with RGB strip so i can dim them down and use them as night lighting for the stairs and when i have more time make it so they change color or something as you walk up them
- Model of CNC Machine: Self built 36x25x7
usLEDsupply
That is a cool idea, keep in mind that the risers on stairs are kicked by toes by folks when walking up.
do you think they would get scratched up?
i was planing on cutting the designs in the back side but maybe i should also put a thin piece of lexan in front or find a thin overlay like what you put on a cell phone to protect them
- Model of CNC Machine: Homebuilt
OK, I have read these threads over and over. I am obviously not understanding something. A couple of the responses here say these acrylic carvings can be done in VCarve Pro. I have the newest version and cannot for the life of me figure out how to make the praying hands (or any 3D carving) in the negative or mold form.
I do not see anything labeled Material Master, is that just Aspire? What am I missing?
VCarve Rooky - SimplyDifferent
Simply Different Woodworking, LLC
- Model of CNC Machine: CNC Shark HD 2.0
Can I get some recommendations on the acrylic carving? What thickness and tool (Bit) are you using? Have you tried using color acrylic or just the clear? As you can see I'm new to this.
Any help and or advise would be appreciated.
creek
creek
creek
Rocky Face, Ga
Rocky Face, Ga
Hi creek, I will tell you what I use, but I'm sure others have different ways then mine. I like to use one inch thick acrylic but have used 3/8" thick also.
First off I invert the profile, check my cutting depths, if all looks good. The rough past with a .125" bull nose w/20% set over. The finish past I use a .0625" bull nose w/ 12% set over.
- Model of CNC Machine: Shark Pro HD and CNCrouterparts 4896
I have got to try this. Does someone have details of what and where to get the stuff.
What plastic, and what is used to light these. Very cool
These are the two web site I have ordered from
https://www.estreetplastics.com
http://www.oznium.com/led-flex-strips
