Cradles for Charity - Free plans and instructions
Postby tmerrill » Thu Nov 26, 2009 6:25 pm
As I sit here smelling the turkey cooking it seemed like an appropriate time to share this.
My woodworking club makes toys that we donate to a local charity this time of year for distribution to needy children. With my CNC I make cradle ends which are ultimately assembled into cradles and distributed with a small stuffed animal and blanket purchased from club funds. Last year I cut 320 cradle ends and assembled 60 myself, using furniture grade plywood. Unfortunately for this year, recent laws/rules put in place by our Consumer Product Safety Commission doesn't clearly define whether the use of plywood is acceptable, so to be conservative we decided to make the cradles out of solid maple. Bottom line, in the time I could make all the parts and assemble the ones from last year, I have got 12 done for this year!!!
But, back to what's important. At ShopBot's request last year, I put together a guide with plans. It never made it to daylight so here it is this year for anyone to use and enjoy. Obviously, you don't have to make them for charity, but I would encourage you to consider it. I never got to see any child's face light up, but I know it happened and it's a great feeling. If you make the cradle to the exact size you see here, it makes a pretty small cradle. But just as I did last year for my grandchildren and some family friends, I took the same plans and sized them up to hold a larger doll. I also V-carved the child's name on each one to personalize them.
Here is what you find below and I'll explain the differences between the 2008 and 2009 designs. Most of the files are in the .zip file.
In the .pdf you will find instructions for making a cradle completely out of plywood, which is the 2008 design. The .eps file is included for ONE cradle end and it is designed to fit into a 12" X 12" area, so by using the Array Copy tool you can easily create arrays of cradle ends to match your material. The vectors for the sides and bottom are simple straight lines and a plywood bit was used to make the slots using a simple profile-on toolpath. Using furniture grade plywood (basically Baltic Birch in 60" X 60" sheets and a Baltic Birch 'type' plywood in 4' X 8' sheets) the joints were very tight and the cradles assembled with glue only.
Important: Please note that these plans assume you have a table saw and the ability to create an angled dado to complete the sides and bottom. If you don't, it wouldn't take much to modify the plans to be completely cut by your CNC.
For 2009, with the change to using solid wood, I decided to pocket for the sides and bottom. Then the wood for the sides and bottom was planed to the width of the pocket. Since seasonal wood movement is greater with solid wood than plywood, I decided to add two screws to each side at each end. Those are the 1/8" pilot holes that you see in the preview. These holes aren't deep, they just mark the position where the actual through holes will be drilled at the drill press. I also did away with the heart shaped holes from 2008. I v-carved two hearts as shown in the preview, but haven't included them in the .eps files as the hearts are traced from the 3D clip-art included with Aspire and are copyrighted by VectorArt3D. But this shouldn't be a problem, you can easily add anything you want or leave it plain.
I'll leave it at that for this initial post. Don't hesitate to ask any questions as the .pdf file never received any reviews last year and I might be making assumptions that don't help all of you.
As a final thought, as we reviewed many plans and decided what to build, it became apparent that traditional toys for little boys were pretty easy to come by - planes, trucks, tractors, etc. Traditional ideas for little girls we found more challenging. That's why I enjoy doing the cradle ends and even thought I only made 12 this year, I know there will be 12 happy little girls.
Happy Thanksgiving,
Tim
Instructions for cradle.zip
(349.23 KiB) Downloaded 3094 times
tmerrill
Model of CNC Machine: ShopBot
Re: Cradles for Charity - Free plans and instructions
Postby glenn » Thu Nov 26, 2009 9:10 pm
Thanks Tim,
Neat!
glenn
Model of CNC Machine: home brew 40x20
Postby ScottBot » Fri Nov 27, 2009 7:19 am
Hey Tim,
Thanks for sharing and happy Thanksgiving.
Scott
ScottBot
Postby Adrian » Fri Nov 27, 2009 1:00 pm
Thanks for sharing Tim. :D
Postby johnnydoughey » Sat Nov 28, 2009 12:34 am
Thanks Tim... nice concept, and simple. I'll try a few between now and Christmas. I know a large population of needy folks and just the nonprofit which would appreciate the gifts...
johnnydoughey
Postby Joe Bloggs » Mon Dec 07, 2009 4:14 am
Being a single custodial parent . . . .
I made these for all the little girls I know of other single parents.
Joe Bloggs
Postby tmerrill » Mon Dec 07, 2009 11:39 am
Joe,
They came out great. Thanks for posting and sharing.
But thanks the most for thinking of others :D
Tim
tmerrill
Postby Joe Bloggs » Mon Dec 07, 2009 12:51 pm
Not done yet, have to do a 220 sanding and shellac and then paint the names, then a final coat of shellac. I used 1/2" plywood because I had it available. 3/4" would be better according to your initial post as that way you can get a better round over on each side of the wood. We used the minwax water based stains. This is the "Dusty Rose" color. My girls helped stain them, we used a large foam brush. The names are really going to pop! The youngest daughter really really wants one. I just kind of hid hers away as we worked.
My mom is making blankets for each of them. Taking two pieces of flannel or fleece, using scraps really. Then using the surger, doing a stitch around the blanket and then using a pinking shears to cut them out. Plus, if you go to http://www.freelettersfromsantaclaus.com you can print out a cute little letter for the child. I have a bunch of Candy Cane envelopes for the letters.
I talked to the Awana church club and the church and next year, we are going to be making a whole boat load. I will get the plywood and cut them, then everyone is coming over to the shop to sand and stain one weekend, and the next will be to assemble. Good thing I put a furnace in the shop this year. It looks to be a big event in the future!!!
Joe Bloggs
Postby swaggs21 » Fri Apr 16, 2010 1:01 pm
Tim,
This is a great idea. I am going to get with the Children's Church director and see how many I need to make. I know there are a lot of girls in our community that would love these, both in and outside of our church. I have seen the topic many times, but I finally decided to reply today :D
-Chris
The new woodworking site:
http://www.33degreeseastww.com
swaggs21
Postby Creation in Wood » Sat Jan 02, 2016 4:40 pm
Four of use made 52- Cradles at my shop in one day for Charity. The Colorado Woodworkers Guild make about 500- toys every year to give to the kids in Shelters. The Cradles were part of the 500- toys. I cut the rocker end panels on my CNC which helped speed up production. I can cut 8- end rocker panels at once. The others cut the slats, sanded and assembled the Cradles.
Thank You
Doug
Creation in Wood
Postby wsteffan » Sun Feb 07, 2016 2:55 am
Doug,
Very nice work with yourself and the Colorado Woodworkers Guild.
I wanted to thank you again for hosting such a great CNC retreat last month.
Wayne
wsteffan
Model of CNC Machine: Shark 60th
Postby Creation in Wood » Sun Feb 07, 2016 3:02 am
Glad you enjoyed the Retreat. Great time
Thank You
Doug
Creation in Wood
Postby ThatGuyJosh » Sun Feb 18, 2018 7:01 am
I know this is an older thread but wanted to thank you for making it available and for giving back to the community. I’m going to make one of these for my little girl and then hopefully a few more for others.
Thanks again
ThatGuyJosh
Model of CNC Machine: ShopBot D2418
Return to Aspire - Gallery
Users browsing this forum: No registered users and 17 guests
