blind dove tails on cnc
I think i saw a post on doing dove tail joints on a cnc some place so any way its a challenge here is first go at it may be intersting for some.
- Model of CNC Machine: CAMaster 508 ATC
Re: blind dove tails on cnc
i want to learn more!! please post your methods and file procedures, i am impressed and am having one of my cnc's modified to allow for the neccessary over hang to do this
jim
jim
Hi James i have a 1.75 overhang on front so should be able to do around 48in one pass. for this i use 1.25 off set on y and 2.5 on x i dont have a clamping method yet just screws for now. i will send file for .5 blind maybe some one can improve on them.John, sorry forgot: profile cut outside .50 deep .375dia. 14 deg dove cutter use only 25 in pm @ 12000 rpm i use .375 end mill for tool path but actually use dove tail cutter instead.
- .5 blind dove tails .5 cutter.crv3d
- (56 KiB) Downloaded 522 times
WOW, i have a much better understanding, that is the best file i have seen
i am off to finish my jig and actually the overhang on mine has to be extended to the same 1.75" john as a result i wil now have a cnc dovetailer
anybody need a powermatic singlehead dovetail machine (now obsolete to me)!!!!
thank you!!
jim
thank you!!
jim
Will you guys please post pics of your jigs?
This is something I would like to add to my cabinetry I cant stand junky drawer boxes...
Jim I was thinking of buying a dovetail machien but I wont if I can make this work!!
Nick
Nick
there is a video here, nick we need to do this i am sure the new upgrades to the vectric software are going to help us in the cabinet world
jim
http://www.talkshopbot.com/forum/messag ... #POST78499
jim
here!!!!
That is what I was thinking thanks for the link!!
I wonder how hard the setup will be...................
Nick
Nick
James sorry the cut depth should have been .375 i am working on through dove tail @ same time.john teichman wrote:Hi James i have a 1.75 overhang on front so should be able to do around 48in one pass. for this i use 1.25 off set on y and 2.5 on x i dont have a clamping method yet just screws for now. i will send file for .5 blind maybe some one can improve on them.John, sorry forgot: profile cut outside .50 deep .375dia. 14 deg dove cutter use only 25 in pm @ 12000 rpm i use .375 end mill for tool path but actually use dove tail cutter instead.
john, i had set it to .375 as i would normal,, so get this i just got off the phone with gary campbell who did the original jig!!! we are working out one nice deal for me to get it here
john i really appreciate this help i hope to be apart of using vectric in the comercial and cabinetmaking business
jim
jim
- IslaWW
Hey Guys...
If you would like some more info on the jig and the geometry behind it, you can look at my webcolumn on the ShopBot website. There are pics of the jig, my cutting files to download (might make translation to G code easier). I also have built, and am using now a 5/8 bit that allow more aggresive cutting.
Heres a link to my column: http://www.shopbottools.com/garysmusings.htm#Dovetail
If you want more info or the 5/8 file, email to islaww(at)comcast.net put dovetail in the subject line to get thru the spam filters.
Gary
Gary
Gary Campbell
GCnC Control
GCnC411 (at) gmail.com
GCnC Control
Very kind of you to post Gary!!
I am going to try to start making a jig fixture this week!!
I have a PC jig did you model the workings of the jig from that?
Nick
Nick
- IslaWW
Nick...
Yes, the cutting files were modeled after the geometry of the PC. In the article on the SB website, there is a link to the PC jig directions on the Rockler website that will allow you cut a number of other joints.
Since I programmed this with the flexibility of SB programming alngusge, I was able to add many variables and build in adjustments. I am not sure what,if any, of this could transfer over to G-Code.
Gary
Gary
Gary Campbell
GCnC Control
GCnC Control
Fascinating discussion and very helpful. For what it is worth I have developed an Excel spreadsheet that produces G-Code for Through Dovetails. You put in the angle and size of the bits, number and spacing of the dovetails, size of the material and it figures all the geometry of the cuts and produces the parameters for a Mach3/G-Code program I wrote. Works pretty slick. The Excel G-code can be copied directly into the Mach3 program and machined. I will be glad to share both the spreadsheet and G-Code program with any who are interested.
Paul
Paul
Cobblewood Carver
fleming, i have sent you a pm. and actually i have several pc and other brands of dovetail jigs i may strip for parts
jim
jim
