Cribbage Boards
Re: Cribbage Boards
Postby NSchlee » Sat Feb 07, 2009 7:55 pm
LT985 wrote:It's all done with a rattle can, I mask off the outside with the blue painters tape. I have a rattle can of walnut stain, put it on thick wipe off with rag leaving more in the corners of the craving. Then another rattle can of high gloss poly, with a light sanding between coats.
LT, what spray stain are you using? I used to use Deft Walnut Spray Stain for blend staining on walnut, but they quit making it. Have yet to find a good replacement.
Neal
NSchlee
Re: Cribbage Boards
Postby LT985 » Sun Feb 08, 2009 9:50 am
The rattle cans used on these were - Behr walnut, Minwax poly- high gloss. I tried to find the stain online to show you a link but I can't find it. I don't know how long it's been sitting on the shelf or where I got it. The minwax high gloss I got 2 weeks ago from the home depot. I'll add some photos when I get back into the shop. I share a shop with my brother, it is about a mile from my house and I only go over there when working on something. Between working fulltime on the graveyard shift and working my woodmizer in my spare time I don't get into the shop as much as I would like to. The only bonus is when I do get into the shop the wood is free.
LT985
Re: Cribbage Boards
Postby silverlake » Sat Feb 14, 2009 7:14 pm
You have yourself some very nice looking boards.
I would like the files to boards #1 and #8.
Time to find time to do something for myself .
Thankyou
georgina@silverlakehardwoods.com
Georgina
silverlake
Re: Cribbage Boards
Postby endgrainguy » Sun Mar 08, 2009 6:19 pm
These boards are definitely a great use of a CNC. A suggestion for the pin storage is to use a tapered door, that would tighten as it's slid in, cut a little short , so no risk of bottoming out. As long as the tapers of slot and door match, it won't have to be made with absolute precision, which ,over time, due to wood movement, isn't really possible.
I"m still figuring out what to do with my CNC to make up for the 30% of the last year I"ve spent building it and learning to use it! Al Ladd www.alladd.com
I thought this was supposed to make life easier?
endgrainguy
Re: Cribbage Boards
Postby sunshinejim » Tue Mar 10, 2009 11:09 pm
With regard to the pin storage in the bottom of the crib board - I have been experimenting with a "keyhole slot bit". When you do the slot for the door you can set the depth to give yourself a good strong lip and just tell the computer that you are using a 1/8" flat end mill - that will give you a good groove all around the opening and then cut the lid to match the groove. As before just mill a recess to hold the pins. Make sure that you start and end the door slot off your crib board.
sunshinejim
Re: Cribbage Boards
Postby crocky » Wed Mar 11, 2009 12:16 am
Magic Crib Boards :)
Could I have a copy of the first one please to bobc@ocm.com.au it will give me something to do :)
Cheers,
Bob
Aspire, VCarve Pro, PhotoVCarve
Blog: http://www.ocm.com.au/wordpress/
crocky
Re: Cribbage Boards
Postby tamathumper » Thu Mar 12, 2009 2:03 pm
Awesome stuff! :D
May I have the files for 1, 5 and 6?
I can't wait to try out that pin storage idea. Do you make the pins too?
CNC: www.bitcarving.com; Hybrid 4x4, RockCliff, Mach3, Vectric Aspire 2 + Wildlife Scenes 1.
tamathumper
Re: Cribbage Boards
Postby holland1vt » Mon Mar 16, 2009 3:05 pm
Would it be possible to get cribbage boards 9 and 10
in DXF format as I have cut2d and cut3d which does not
support CRV format.
Thanks for already making the CRV files available to us.
hollandvt@verizon.net
Ed
holland1vt
Re: Cribbage Boards
Postby rj_packwin » Thu Mar 19, 2009 12:48 am
Those are great looking boards ... could have a copy of #1 board. I have a brother-in law in Upper Michigan who is an avid deer hunter. He has a great log cabin camp that they hunt from and this would make an excellent gift that I would like to personalize for him.
Ray
We should set up an on-line cribbage tournament for all who are interested.
rj_packwin
Re: Cribbage Boards
Postby JamesB » Thu Mar 19, 2009 1:57 pm
Just to let everyone know - the deer in the first board is a Vector Art 3D model. I have PM'd the author of this thread to make sure he knows he should not be sending this part off the design (although I have not heard back from him). The design is part of the clipart that comes with Aspire so if you have Aspire you already have that model so can set it up yourself. If your not an Aspire owner you can buy it from here if you want to use it: http://www.vectorart3d.com/store/index. ... l&ID=50052
James
JamesB
Vectric Alumni
Re: Cribbage Boards
Postby joecnc2006 » Thu Mar 19, 2009 2:05 pm
JamesB wrote:Just to let everyone know - the deer in the first board is a Vector Art 3D model. I have PM'd the author of this thread to make sure he knows he should not be sending this part off the design (although I have not heard back from him). The design is part of the clipart that comes with Aspire so if you have Aspire you already have that model so can set it up yourself. If your not an Aspire owner you can buy it from here if you want to use it: http://www.vectorart3d.com/store/index. ... l&ID=50052
James
Thats a good point if people share files they need to adhere to the copy write of files contained within the design.
joecnc2006
Re: Cribbage Boards
Postby LT985 » Mon Mar 23, 2009 6:54 am
I have not and will not share the files. Those that read this forum know that when asked for the file I didn't share it. I took the time to write a "how to" make it in ten minutes. It can be found here viewtopic.php?f=29&t=4844
LT985
Re: Cribbage Boards
Postby Hunterland » Sun Mar 29, 2009 4:08 am
Great work on the cribbage boards could I please get the file for the first board that turned out great! Do you just use a end mill for all the holes or a drill bit? A gain great work! thanks Don
Hunterland
Model of CNC Machine: prs standard
Re: Cribbage Boards
Postby jhegel » Tue Mar 31, 2009 4:12 am
LT985 wrote:I have not and will not share the files. Those that read this forum know that when asked for the file I didn't share it. I took the time to write a "how to" make it in ten minutes. It can be found here viewtopic.php?f=29&t=4844
Nice work on the tutorial.
It took me about an hour to recreate the "Deer in th Woods board".
It also showed me new and creative ways to use Aspire.
jhegel
Re: Cribbage Boards
Postby GaryR6 » Tue Sep 06, 2011 3:19 pm
Thanks for the files. Nice work
GaryR6
PreviousNext
Return to Aspire - Gallery
