US Flag on Work Shop
Postby TReischl » Fri May 17, 2019 2:03 am
I have been working on this one awhile. It measures 36 inches long by about 22 tall. Mounted it below the all night shop light. I am not much of a photographer soooo. . . . .
Here is one my wife took, she is obviously better with a camera!
Re: US Flag on Work Shop
Postby CrowsWW » Fri May 17, 2019 2:32 am
That looks real nice. Great Job!
Troy Crow
Crow's Woodwork's
http://www.crowswoodworks.com
I have a day job to support my wood habit!
CrowsWW
Model of CNC Machine: ShopSabre 4896
Postby highpockets » Fri May 17, 2019 2:48 am
Beautiful work Ted, you're getting some mileage out of that eagle.
Postby mark-s » Fri May 17, 2019 4:09 am
Love the theme.
Take a picture in day light and post.
Looks great.
mark-s
mark-s
Model of CNC Machine: diy 4 X 4 CNC Router
Postby Todd Bailey » Fri May 17, 2019 8:30 am
Hello TReischl...
That looks FANTASTIC!!! Well done! Thanks for sharing.
Todd Bailey | Design and Make
DesignAndMake.com
Todd Bailey
Vectric Staff
Model of CNC Machine: CraftCNC
Postby WNC_Ed » Fri May 17, 2019 12:28 pm
Ted,
That looks absolutely spectacular!
Congrats!
Maker of sawdust
WNC_Ed
Postby garylmast » Fri May 17, 2019 1:12 pm
Love the theme.
Looks great.
mark-s
Plus 1
Gary
garylmast
Postby dwilli9013 » Fri May 17, 2019 1:23 pm
Very Nice Ted. The lighting gives it a very cool effect. Thanks for sharing. :lol: :lol: :lol:
D-Dub
Dwayne
Dwilli
dwilli9013
Postby TReischl » Sat May 18, 2019 1:37 am
OK, my better half got a nice pic this evening:
This actually shows the waves in the flag. Taken right near sunset.
Thanks for all the compliments!!!!
Postby mtylerfl » Sat May 18, 2019 2:35 am
That looks fantastic, Ted!
Postby scottp55 » Sat May 18, 2019 11:06 am
VERY Nice Ted!! :)
Looks VERY deep...What was total depth, and where was the spot most in danger from the collet nut(before clearing)?
LIKING it!
GMH
scottp55
Postby mezalick » Sat May 18, 2019 11:37 am
Last picture looks great.
Nice work.
Michael
Michael Mezalick
https://carveddetails.com
mm@mezalick.com
mezalick
Postby TReischl » Sat May 18, 2019 12:42 pm
scottp55 wrote:VERY Nice Ted!! :)
LIKING it!
Total depth is 2.7 inches. The deepest place was along the eagle's throat. That was an issue because I had neglected to add a bit of taper and the software was cutting inwards towards the center at that point so all the material was still there. What I did was define an oval area around the throat so that it would cut from the inside out removing the step of material first.
My biggest challenge these days is painting. My first issue is that I get in too much of a hurry to see a project completed (aka the little boy syndrome). Second is prep, I am getting much better about that. Third is the type of paint. Latex is great to work with, fast drying, easy cleanup, etc, but I am starting to think that oil based paints produce better results.
The flag is made from big box pine that I made sure had dried out. I culled it for knots, ripped it to the 2.7 thickness, flattened both sides and then face glued it. Pine gets a bad rap all the time because it rots. That is both true and false. If you paint pine and then mount it so that water cannot be trapped on its surface it will last longer than most of us. So what I do is use standoffs on the backside so the water is not trapped between the sign and the building. I just use a couple of thin strips of white oak which is highly rot resistant in a vertical position. That way water is never trapped behind the sign. I sort of figured this out by looking where some adirondack chairs I built about twenty years ago had started to rot. Of course on the bottom of the legs from wicking water up and also wherever there were any places that water would get trapped, like where the back slats met the seat.
There are a couple of reasons I do not just use treated SYP. First is that the dust from it is downright unhealthy, secondly is that it sands lousy, third is that it is really fast growing which makes for huge grain that tends to splinter easily when cutting.
I am not in the mode of building monuments that future generations will "Oooo, and Ahhhhh!" More than likely whoever buys this place after they plant us will say "What is with that flag? It's gotta go!" or maybe not, in which case they can get out their paint brushes and give it another coat. I did use stainless steel screws to mount it so that they do not rust and run down the face of the flag.
Postby scottp55 » Sat May 18, 2019 12:47 pm
Thanks Ted!! Hadn't thought of that.
Yep, Aspire Would come in handy to give a little slope to a near vertical surface!
Maybe one day :oops:
Thanks!!
GMH
scottp55
Postby mtylerfl » Sat May 18, 2019 12:56 pm
Ted,
Did you take any photos of the raw glue-up and photos during/after the carve (before painting)?
Next
Return to Aspire - Gallery
Users browsing this forum: 01f4irider and 3 guests
