Aztec and Mayan Calendar Theme Salad Bowl Guitar
Hey, they are both round, so why not use them on another weird guitar build?
I used three of the symbols from the Mayan Haab calendar on the fret board for Vcarved decoration, and another one to decorate the tailpiece.
The bridge is sort of a pyramid also. The top and bottom panel are made of 3mm 5 ply aircraft grade plywood that I have used in building
radio control model aircraft over the years. The calendars are carved just 0.030" deep with a Whiteside #1540 60 degree carbide cutter. Both
panels are dark stained with General Finishes Java gel stain. The symbols on the fret board are stained with General Finishes black gel stain. The
red wood is Padauk, the brown layer under the fret board is black walnut. The neck is red oak. The bowl is an 11" diameter bamboo salad
bowl from IKEA. The tuners, fret wire, dual piezo pickup kit, skull knob, and strings are from C.B. Gitty Crafter Supply. 25" tuning length. Tuned to DGBE.
I finally upgraded my Aspire 8.5 software to v9.516 recently and used it to create this project.
CarveOne
CarveOne
