Precision Machining
Precision Machining
Postby highpockets » Fri Mar 29, 2019 2:52 am
So you think your CNC can hold tight tolerances. :lol: :lol: :lol:
https://www.youtube.com/watch?v=1K9o5ltWozY&t=23s
Re: Precision Machining
Postby gkas » Fri Mar 29, 2019 5:46 am
Wow!!!
gkas
Postby FixitMike » Fri Mar 29, 2019 6:18 am
Around 1979, the company I worked for purchased a CNC mill to manufacture sideplates for the printing presses we built. Before then, printing press side plates were typically bored in pairs so the printing cylinders would be guaranteed to be parallel. A customer questioned that our method of manufacture was sufficiently accurate. The accuracy was demonstrated by placing 2 sideplates on top of each other, located by steel dowels in matching holes. We then placed a 6" diameter ball bearing in the upper plate, and it slowly slide down and into the lower plate without hesitation. This was repeated for all 3 cylinder locations. The customer was convinced.
I suspect that the pieces in the video were EDM (Electric Discharge Machined). That type of demonstration was typically used to show the accuracy of the process.
FixitMike
Postby Leo » Fri Mar 29, 2019 1:12 pm
I work in gage making currently and daily at tolerances in the single millionths of an inch. Working in +/- .0001 or .0002 is a pretty wide open tolerance to me. I have a Studer S33 that is capable to .000010 accuracy.
Still, that video is fascinating to me, partly because I realize what it takes to do that work.
A lot of it is grinding but most of it is done by finish lapping. Wire EDM is good to .0001 and on occasion with super detail to .000050. Generally the finish is a dull finish, but can be polished and lapped.
No matter, what I am amazed at what can be done.
That was an awesome video - thank you
www.leosworkshop.com
Leo
Postby ger21 » Fri Mar 29, 2019 1:35 pm
Sure seems like those outside faces are ground after assembly to get that perfect "disappearing joint".
ger21
Postby scalci » Fri Mar 29, 2019 2:15 pm
Wow this is incredible...
scalci
Model of CNC Machine: Home Build Mach3
Postby dwilli9013 » Fri Mar 29, 2019 3:23 pm
Pretty awesome video. I would suspect that caliper machining would be done in a climate controlled clean room. Pretty amazing I can't stop watching the video. Thanks for sharing that. :lol: :lol: :lol:
D-Dub
Dwayne
Dwilli
dwilli9013
Postby BradyWatson » Mon Apr 01, 2019 1:53 am
Really cool...I like the helical one. It would make a great 'desk fidget' :D
Gauge blocks anyone: https://youtu.be/gbsd2OpPOMw
High Definition 3D Laser Scanning www.IBILD.com
BradyWatson
Return to Aspire - Gallery
