Butterflies on Walnut Vase
Postby Fleming » Mon Jan 28, 2019 12:41 am
This is a recent piece done on the indexer. The shape and butterflies are 3D carved and the background
plantings are V-carved. The wood is black walnut. Vase is about 9" tall and 3" diameter.
Walnut vase
Cobblewood Carver
Fleming
Re: Butterflies on Walnut Vase
Postby highpockets » Mon Jan 28, 2019 12:46 am
Beautiful work. Like the design as well as the workmanship.
Postby dwilli9013 » Mon Jan 28, 2019 2:28 pm
Very nice work. Pushing me to get my rotary up and going. Thanks for sharing. :lol: :lol:
D-Dub
Dwayne
Dwilli
dwilli9013
Postby mfirlott » Mon Jan 28, 2019 4:28 pm
Very, very nice indeed.
If you carved the outsides on the indexer, how did you do the inside of the vase?
Thanks for sharing.
(Mitch)
CAMaster Stinger I
Vectric Aspire v8
Epilog 45watt Helix Laser
mfirlott
Model of CNC Machine: Stinger 1 (2014)
Postby TReischl » Mon Jan 28, 2019 6:40 pm
mfirlott wrote:If you carved the outsides on the indexer, how did you do the inside of the vase?
Thanks for sharing.
Not sure how the OP did it, but I do it by turning on a lathe. The reason I am commenting is that I do it a little differently than most people would think.
I turn the inside first on the lathe. In my case I use a home made deep hollowing rig and a laser light to control wall thickness and depth.
Then on the rotary axis I turn a short "spud" that fits snugly inside the piece and use a tailstock to keep it from falling off. To get a tight fit on the spud, I use paper towel. By using a spud it is possible to turn past the upper lip on the vessel. Using jaws to do this type of thing gets to be problematic at best.
A really fun thing to do is use a forstner bit to "turn" the inside of small boxes and then put them on the rotary using the method above.
Postby Fleming » Mon Jan 28, 2019 9:19 pm
Thank you for the nice comments. I do the same as Ted, turn the inside on the lathe and rough shape the outside. My lathe and rotary use the same 1X8 tpi threaded connection so moving from one to the other is simple.
Cobblewood Carver
Fleming
Return to Aspire - Gallery
