3D Horned Skull
3D Horned Skull
Postby mfirlott » Thu May 10, 2018 4:12 pm
First try at modelling a 3D object using new 2-sided features in Aspire.
As this was a "test", was done in MDF and simply slapped some paint over it to see what it could look like.
Worked out real well. Used a model I got from Thingverse, then using Windows 10 3D Builder I split the model into 8 horizontal slices of 3/4" each. After that, took each slice into Aspire and ran a 2-sided machine job then glued the 8 parts together.
Am very, very happy at the outcome and plan to do more 3D models.
(Mitch)
CAMaster Stinger I
Vectric Aspire v8
Epilog 45watt Helix Laser
mfirlott
Model of CNC Machine: Stinger 1 (2014)
Re: 3D Horned Skull
Postby garylmast » Thu May 10, 2018 8:14 pm
Looks like it came out well.
garylmast
Re: 3D Horned Skull
Postby martin54 » Sat May 12, 2018 1:15 am
Looks like it came out very well, curious though why you used 3D builder to slice it rather than just using the tools in Aspire, one of the things I haven't really tried yet so don't know how well it works with Aspire, seems to be OK from the tutorial though :lol: :lol: :lol:
Re: 3D Horned Skull
Postby mfirlott » Sun May 13, 2018 1:01 pm
Used 3D Builder as it repairs broken or open areas as it slices.
I can also view the model in multiple views as I rotate it around.
I also find that when I import object into Aspire to slice, the undercut areas show up as flat surfaces that go to the material surface so I do not what to slice it in Aspire...is not a true view of the model (if it has undercuts).
(Mitch)
CAMaster Stinger I
Vectric Aspire v8
mfirlott
Return to Aspire - Gallery
Users browsing this forum: No registered users and 22 guests
