Fender Stat Build
Fender Stat Build
Postby Crosetti » Tue Oct 10, 2017 9:29 pm
Hello, the boy has been into guitars lately & he asked me, "Why don't we make one on your fancy machine"? It's turning out nice so far...
One of the test cuts in plywood
Fresh of the machine
Finished body in between clear coats
Crosetti
Model of CNC Machine: work: Camaster Stinger III / home: Shark
Re: Fender Stat Build
Postby dwilli9013 » Tue Oct 10, 2017 10:13 pm
Well now you know what to tell him........... :lol: :lol: Nice work especially for a first of. Be sure and post the final pics.
D-Dub
Dwayne
Dwilli
dwilli9013
Postby Crosetti » Tue Oct 17, 2017 2:41 pm
She’s complete! No paint, we liked the natural look. It turned out nice. Now I want to build more
Crosetti
Postby dwilli9013 » Tue Oct 17, 2017 3:02 pm
Nice Job thanks for the finished photos. :lol: :lol:
D-Dub
Dwayne
Dwilli
dwilli9013
Postby woody53 » Tue Oct 17, 2017 8:24 pm
Love the natural finish. Both my sons play guitar and my oldest has 4 strats, one of which I bought him 35 years ago. Wish I had your talent to make him a strat like that.
Beautiful job, thanks for posting.
Dave
woody53
Model of CNC Machine: Probotix Meteor 25 x 50
Postby Crosetti » Fri Oct 20, 2017 7:08 pm
Crosetti
Postby dwilli9013 » Fri Oct 20, 2017 7:14 pm
Crosetti wrote:a coworker playing it...
https://youtu.be/UKo3KVvvLGg
https://youtu.be/vUEHq8ok3Wc
Nice that's like icing on the cake. :lol: :lol: :lol: :lol:
D-Dub
Dwayne
Dwilli
dwilli9013
Postby dvaskie127 » Fri Oct 20, 2017 9:37 pm
Awesome work on the body it turned out great. Did you also make the neck?
dvaskie127
Postby Crosetti » Sat Oct 21, 2017 4:09 pm
The way we built it was the easy way. For this first attempt I bought a neck, a loaded pick guard & all the bits. So it was like a kit without a body. I made the body then we put it together. It was a totally fun project for me & the boy. Now he has a guitar that he helped make & that's the best part.
For the next one I'm going to attempt to CNC the neck. Either just CNC the neck profile & hand shape the curvature, or find a good 3D model then I can CNC it all, we'll see...
Crosetti
Postby CarveOne » Mon Oct 23, 2017 10:40 pm
Very nice work on your guitar. There is a lot of information on the CNC Zone website about building these with CNC machine techniques. Specifically in the Musical Instrument and Design section. You can probably find links todownloadable CAD files for some of the more popular guitars.
http://www.cnczone.com/forums/musical-instrument-design-and-construction/?s=6c3550c8803d39f30c6ebea2aa761df5
CarveOne
CarveOne
CarveOne
Postby Crosetti » Tue Oct 24, 2017 6:12 pm
WOW! Thanks CarveOne!!!!!!!!!!
Crosetti
Postby CarveOne » Wed Oct 25, 2017 1:33 pm
You're very welcome.
If you plan to create a new neck from scratch, you can find online fret position calculators on the following two sites. I usually use the one at the Stewart McDonald website, but they are both very useful.
http://www.stewmac.com/FretCalculator
http://www.liutaiomottola.com/formulae/fret.htm
You can have your CNC machine cut the fret slots with a small end mill, or mark them with a 60 degree sharp point V-bit for hand sawing them to depth. Accuracy of the spacing is as good as your machine's accuracy.
CarveOne
CarveOne
CarveOne
Postby Crosetti » Wed Oct 25, 2017 8:05 pm
CarveOne
Good to know, I'll make the fret board on the Camaster @ work. Its much more accurate than my little CNC Shark.
Crosetti
Postby CarveOne » Wed Oct 25, 2017 10:46 pm
Your fret board will need a 3d model of the proper radius of the fret board. Then when you place vector lines for the fret cuts, draw a vector at the zero fret location. Then use the Offset tool to place a copy of the zero fret vector at each of the calculated fret locations. The fret vectors need to have the Project Onto Model option enabled when you set up the tool path for this operation. With an 0.023" diameter carbide end mill fret slots should be started just off to one side of the fret board outline so that it starts cutting on the side of the cutter and exits the fret board just off of the other side. CNC is much easier than hand sawing the slots if you have all of the operations planned out properly.
All of my cigar box/salad bowl guitar necks have flat fret boards. Much easier to make by hand or CNC machine. Usually three string, but a couple of four stringers may appear in the future.
CarveOne
CarveOne
CarveOne
Postby Rick Hubka » Thu Oct 26, 2017 6:10 pm
Fantastic Strat Build!
Can you tell us where you got your strat body cut file. I don't mind paying for one as apposed to a hundred hours of my time to learn to make one poorly. :D
You can find tons of Strat copy guitars around for a hundred bucks but nothing beats saying you built it yourself!
Rick
Rick Hubka
Model of CNC Machine: Joe's 4x4 Hybrid R&P Evolution
Next
Return to Aspire - Gallery
Users browsing this forum: Majestic-12 [Bot], Tailmaker and 21 guests
