Page 1 of 1
Wedding Gift Wine Caddy
Posted: Mon Oct 09, 2017 4:50 pm
by dwilli9013
Well another wine caddy has been released into the wild.
This one done in Aspen. I try to change the finish up on every one of these I do and I believe this is my favorite thus far.
Used Antique Oil Finish on this one 4 coats with 24 hour cure in between each coat. This did not come out overly shiny as the others done in poly but it has a fantastic silky feel to it.
Thanks for looking
Dwayne
Re: Wedding Gift Wine Caddy
Posted: Mon Oct 09, 2017 5:18 pm
by Mike-S
Came out great. The finish is perfect for that holder. They'll love it.
Looks like aspen carves well.
Posted: Mon Oct 09, 2017 5:29 pm
by dealguy11
That is quite nice. The carving came out beautifully detailed.
Posted: Mon Oct 09, 2017 5:38 pm
by dwilli9013
Thanks both of you.
Yes Aspen carves quite well you just have to brush the fuzzies with and stiff bristle brush and watch the bit speeds it will burn in a pair of seconds.
.03 rad tapered ball nose brings out the detail quite nice but does add the time. Worth the trade off as I am not doing production runs on these.
Posted: Mon Oct 09, 2017 6:04 pm
by highpockets
Nice job Dwayne....
Great wedding gift, does it come with a bottle of wine and glasses
Posted: Mon Oct 09, 2017 6:05 pm
by mtylerfl
Beautiful job!
Posted: Mon Oct 09, 2017 6:26 pm
by dwilli9013
Posted: Mon Oct 09, 2017 6:58 pm
by jwbyers
Looks very nice! Good finish, very detailed. What bit did you use for the "Established Oct 6, 2017"? Looks really tight in there.
Posted: Mon Oct 09, 2017 7:50 pm
by SteveNelson46
I LIKE it. Did you design it or is the pattern available?
Posted: Mon Oct 09, 2017 7:53 pm
by dwilli9013
jwbyers wrote:Looks very nice! Good finish, very detailed. What bit did you use for the "Established Oct 6, 2017"? Looks really tight in there.
Thank you I used an Amana Tools Carbide insert bit Engraving - 30 Deg Tip 0.02 Flat- 0.25 inche shank. These are my go to bit for tight areas. For extreme detail I will go with an 1/8 inch 60° v-bit.
Posted: Mon Oct 09, 2017 7:58 pm
by dwilli9013
SteveNelson46 wrote:I LIKE it. Did you design it or is the pattern available?
Thank you. The plaque outline is an Vectric clipart in Aspire as are the grapes and the flourish around the last name. all I added was a 2 rail sweep around the glass holder slot and a 2 rail sweep around the bottle hole.
Then my final toolpath is to cut the slots for the glass holders and the hole for the bottle neck. Brand it and send it on its way.
