Dining room table
Dining room table
Postby dealguy11 » Mon Oct 09, 2017 4:17 pm
No carvings on this, just a really big table that fitted together beautifully. Used Aspire to cut the "pie" pieces for the table top, and also the thick oak pieces around the edge. Also cut the large disks and rings that are inside the round base, and an underlayment piece to stiffen up the top. There is no filler on the pie pieces - they went together so precisely and closely that there were no gaps. Table is white oak with a cerused finish and is 84" in diameter.
dealguy11
Re: Dining room table
Postby dwilli9013 » Mon Oct 09, 2017 4:21 pm
Very Nice. Really like the ring around the outside. Someones lucky to receive this one.
D-Dub
Dwayne
Dwilli
dwilli9013
Postby LittleGreyMan » Mon Oct 09, 2017 5:03 pm
I like this very simple but perfectly manufactured design.
Best regards
Didier
W7 - Aspire 8.517
LittleGreyMan
Postby mtylerfl » Mon Oct 09, 2017 10:19 pm
Holy smokes, that is a gorgeous table, Steve! Looks perfect!
carvebuddy.com
Postby Daniel S » Tue Oct 10, 2017 6:55 am
WOW...
That is really a beautiful design and could not be more pleasing to the eye. Very well done, you should be very proud of your work.
Thanks for sharing.
Dan
Daniel S
Postby mikeacg » Tue Oct 10, 2017 2:01 pm
Steve,
As always, beautiful work! Love the design and your execution is flawless...
Mike
mikeacg
Postby Keith Larrett » Wed Oct 11, 2017 1:25 am
Wonderful work!
Did you need to take any precautions to prevent the points of the pie from getting damaged while routing them out?
https://www.syzygywoodworks.com
https://www.facebook.com/SyzygyWoodworks
Keith Larrett
Model of CNC Machine: ShopBot
Postby dealguy11 » Wed Oct 11, 2017 1:51 am
No, not really. I cut them out with a 3/8" compression bit, which cuts down from the top and up from the bottom. This prevents the veneer from blowing out during routing. It's 3/4" material, which can be cut in a single pass on my machine. Also did the cutout in conventional direction, which leaves a nice finish on the cut during cutouts.
dealguy11
Postby Creation in Wood » Sun Oct 15, 2017 3:25 pm
Beautiful table and great design.
Thank You
Creation in Wood
Return to Aspire - Gallery
Users browsing this forum: No registered users and 28 guests
