I volunteer at the local food bank (Tri-Lakes Cares). I made the sign for the Help Yourself Market area, where clients come in and are able to pick out there own food from what is available that day.
Size: 42" x 24" x 3/4"
Software: Aspire 9.010v
Finish: Milk Paint & Cat Varnish
Wood: Alder
- Creation in Wood
- Model of CNC Machine: Legacy Maverick ATC 4x8 CNC
- Model of CNC Machine: FLA Saturn 4x4 / 7W & 60W lasers
Re: Help Yourself Market
That's a unique background texture, Doug. At first site, I thought you were using particle board.
Great job, as usual, on the finishing. I have yet to try that milk paint method you had told me about.
Dave
https://lakesedgewoodcraft.com/
- Creation in Wood
The back ground is a Vectric Clip Art (Leaves)
Dave, you need to try the Milk Paint. The colors are great and it is easy to use and no wast.
Thank You
Doug
Doug
- highpockets
Great job Doug!!!
I really like the background, very inventive.
I haven't tried the milk paint either, just another method to put on the list.
- Creation in Wood
You should try Milk Paint. You will like using it.
Milk Paint is the only paint that I use. You can leave it on the shelf for 100 years and it is still good to use.
There are two manufacturers
Old Fashion Milk Paint - pastel colors
Real Milk Paint - Bright colors
Thank You
Doug
Doug
