Pizza Board
Re: Pizza Board
Postby Fisheye » Thu Jun 01, 2017 10:54 pm
Way cool I have to make some of these.
Great job.
Fisheye
Model of CNC Machine: ShopBot PRT
Re: Pizza Board
Postby martin54 » Sun Jun 04, 2017 2:56 pm
weirdbeard wrote:Thanks guys, if I ever manage to sell one with the engraving on the base ill post it up.
I was a little disappointed with this one as the base was too thin and bowed a little, not bad enough to be wrecked but not perfect either.
Some might actually call the bow a feature as now if placed on a flat surpface it can spin like a lazy susan 8)
Only problem with that is that if it is a feature you have to be able to re create it which probably isn't as easy as it sounds the way wood behaves or doesn't when you want it to :lol: :lol: :lol:
Re: Pizza Board
Postby 4DThinker » Sun Jun 04, 2017 3:51 pm
martin54 wrote:Only problem with that is that if it is a feature you have to be able to re create it which probably isn't as easy as it sounds the way wood behaves or doesn't when you want it to :lol: :lol: :lol:
Naw. Just mark the bowed ones as "Special Editions" with a 50% upcharge. ;)
4DThinker
Re: Pizza Board
Postby myxpykalix » Tue Jun 06, 2017 4:41 pm
Do you have any dimensions you could share? Diameter, thickness of slice holders, base, toolpath info, ect because it looks like you rounded over your edges?
myxpykalix
Re: Pizza Board
Postby weirdbeard » Tue Jun 06, 2017 5:17 pm
Hiya, The Board is made to suit a 12" pizza. I used a point cutting roundover bit (I think thats what you call them :?) and setup a custom Form tool in Vectric to get the rounded edges
weirdbeard
Model of CNC Machine: Jcut
Re: Pizza Board
Postby SamPris » Mon Jun 26, 2017 3:16 am
weirdbeard wrote:Hiya, The Board is made to suit a 12" pizza. I used a point cutting roundover bit (I think thats what you call them :?) and setup a custom Form tool in Vectric to get the rounded edges
Liked your design so much decided to give it a try( hope you don't mind). Very similar to your design 12" pizza, 1/4" Point Cut Round Over. Edge glued birch wood, used Zinsser's Universal Shellac Sealer which I sanded off once all parts were cut. Used Mineral oil and it came out good yet feel it can be tweaked a tad more.
I have to figure out how to post images correctly once I do I will post results.
Thank you for the fun design.
Frank
SamPris
Model of CNC Machine: Shark HD 2.0
Re: Pizza Board
Postby Mike-S » Mon Jun 26, 2017 6:00 pm
Keep the file under 2MB.
Mike-S
Re: Pizza Board
Postby SamPris » Mon Jun 26, 2017 9:05 pm
I knew how to upload just didn't know the size limit for the file(s). Kept getting a blank white screen ... I now I know 2MB limit
Thanks for resonding
Frank
SamPris
Re: Pizza Board
Postby SamPris » Wed Jun 28, 2017 6:32 pm
Finally able to post images of the edge glued birch pizza board design copy from weirdbeard's design. It came out good yet feel it can be tweaked a tad more.
Frank
SamPris
Re: Pizza Board
Postby weirdbeard » Thu Jul 06, 2017 9:51 am
Nice Work Frank!!
Its nice for me to see the design being copied :)
weirdbeard
Re: Pizza Board
Postby georgemon » Wed Jul 26, 2017 5:56 pm
how i find this design? thanks
georgemon
Model of CNC Machine: DIY 2 meters - 3 meters design
Re: Pizza Board
Postby SamPris » Wed Jul 26, 2017 6:15 pm
Do as I did use the original pictures as reference then create the design from scratch using Vcarve Pro. Or if you have Aspire.
By doing so you get to use many of the features/tools when designing this. I found it to be a fun project learned a few things along the way.
Frank
SamPris
Re: Pizza Board
Postby SamPris » Wed Jul 26, 2017 6:17 pm
weirdbeard wrote:Nice Work Frank!!
It was fun recreating it learned a few things along the way.
Frank
SamPris
Re: Pizza Board
Postby BallardMillworks » Sat Aug 05, 2017 4:12 am
Wonderful design. When you perfect it you should sell the pattern online - I'll bet people would pay for it as a project - especially if you did the lazy susan bottom for real.
BallardMillworks
Model of CNC Machine: Shopbot Buddy
Re: Pizza Board
Postby Fred P » Thu Oct 25, 2018 4:24 pm
my first vist to the forum. new to cnc interesting project. can you tell me the diam. of the tray in inches?
would like to try my hand at creating this. Fred/ Florida
Fred P
Model of CNC Machine: shopbot desktop max
PreviousNext
Return to Aspire - Gallery
