Corian clock
- Xxray
Corian clock
Never done a clock in corian, probably because most of what I have is .5 and my clock stems are for .25 movements.
So I set about to make some custom thickness. First I tuned my bandsaw for a nice straight cut which got it real close to where I wanted, then through the drum sander that brought it to a uniform .29.
The reason I need such accuracy is that I use a very fine engraving bit to do these, and if level/thickness is even a hair off it will cut on one side and not the other, or just right on one side and too deep on the other.
So once I got it to uniform thickness I mounted the blank to my jig and perfectly leveled it. I used one of the outer circles to test it, really close to where I wanted. Had the toolpaths calculated at .009, jacked that up to .011 and called it good.
Came out real nice, about 10x10 and a custom matching corian base. Could have put in numbers obviously but I wanted the design as large as possible and numbers would have greatly reduced it ,,, So I opted for pocketed hash marks for the hours.
In case anyones wondering, here is how I black it.
After the etching I give it a quick sanding and blow it off, then I spray paint the whole design black. I use a credit card type card to skim off excess paint, making it much easier to sand when dry.
After the surface has been sanded only the engraving retains the black. Another blow off, then I give it a matte clear coat to make it pop.
2nd pic is one I did a few weeks ago, similar but alot thinner and no clock. This one I went a bit too deep and if you have an eye for details, you'll notice it is no where near as detailed as the clock. You lose details with depth, but diligent prep work allows you to make accurate, very lights cuts.
Doug
- Model of CNC Machine: shark pro
Re: Corian clock
Nice job X-ray.I have some .250 stock I have had for bout 3years.If ya need a pc. Let me know.I will send you one out.What part of Mich.Do you live in? Basecircle
Re: Corian clock
I've made several clocks from .5" Corian. I may have posted a pic, I don't remember.
I just cut a pocket on the backside, slightly larger than the movement. There are also movements available with longer shafts for use with thicker materials. I prefer the pocket, since it sets the movement into the clock and the hanger can be utilized.
- Xxray
Re: Corian clock
Thanks for the offer base, Detroit area.
I actually have corian coming out of my ears, have stacks of it along my fence so I'm pretty well set.
A bit of an effort to get .5 to .3 but worth it, very versatile material.
Doug
Re: Corian clock
No problem Doug.All your work are very nice.One of my favorite's Are your S.O.A keep up the good work.I am in Southgate. Basecircle
- Model of CNC Machine: Home built wooden machine - Mach3/Aspire
Re: Corian clock
Like Samson said....I determine how deep of a pocket to cut to accommodate my clock insert and use the 1/2" corian. This also helps when hanging the clock as it brings it closer to the mounting surface.
Of course with a free standing clock like yours, the mounting offset is not a problem.
Nice work by the way......
Paul
Paul
- Model of CNC Machine: 2 SCM Routech Record 120s(1999, 2001)
Re: Corian clock
Im Detroit area as well, Ferndale to be exact. I have been wanting to mess with some corian, might you have some extra to share? I am a sawyer if you would like to trade for some wood.Xxray wrote:Thanks for the offer base, Detroit area.
- Xxray
Re: Corian clock
No not looking to off any corian, I have a lot but I am a guy who needs a lot - In fact, I am always looking for more.
I got lucky on craigslist months ago, got a truck full for less than $100.
Here is a guy who has some, ad has been up for months so you might be able to knock him down on the "firm" part
https://detroit.craigslist.org/wyn/mat/6101385690.html
Doug
- dhellew2
Re: Corian clock
Very nice use of corian!
I run corian thru my planer fairly often.
The cutter head is a spiral with carbide inserts and I can vary the feed rate
I have not tried it with tool steel cutters but I don't see any reason why it should not work.. maybe I will try one the next time I change blades
I limit cutting depth to 1/32"
Dale
Dale
Young = time, no money
Old = money, no time
Dale
Dale
- Xxray
Re: Corian clock
I got rid of my Makita planer a while back, hated to do it but between the bandsaw and drum sander, it was obsolete, never used it.
When I did have it I tried corian, worked but extremely slow and very messy. Bandsaw is quick n clean. Not ideal use for the drum sander though, will clog up the belt easily if not very careful.
Doug
- Model of CNC Machine: DIY
Re: Corian clock
Nice work! I usually cut a pocket from the back side in the shape of the clock works to allow for a short stem.
- Xxray
Re: Corian clock
I should point out that the reason I slice corian is not specifically to make it thin enough for a clock stem, but rather just minimizing waste.
I will put the cutout pieces to use, in fact already have. As expensive as corian can be, if I can double up on a chunk that is $$ in the bank.
Doug
