I am GROOT
- Model of CNC Machine: Laguna iq
I am GROOT
Here's a sign recently did. It's made of Pine, and is 8 1/2" x 15". Not only did I get to use my cnc, but also got to my jointer/ planer on a 2"X11" building lumber. I had hanging around. The only thing I noticed was some areas no matter how much I sanded, the fuzzies came back.
- kp91
- Model of CNC Machine: Digital Wood Carver
Re: I am GROOT
looks great.
Now you need to do 'baby groot' out of a 2 x 6
Doug
1 John 1:9
Fredericksburg, VA
1 John 1:9
Fredericksburg, VA
- dwilli9013
Re: I am GROOT
Nice work I have been considering the same thing myself.
Thanks for sharing. Isn't Groot supposed to have some fuzzies??
D-Dub
Dwayne
Dwilli
Dwayne
Dwilli
- Leo
Re: I am GROOT
You can seal the fuzzies with shellac before sanding - it helps but not perfect.
- TReischl
Re: I am GROOT
Leo is on the right track.
Use sanding sealer (thinned out shellac, you can make it yourself with a bit of alcohol). Thin works really well because the thin mixture carries into the pores well.
After that, I use about 220 or so sandpaper to defuzz. Then, I reapply the sanding sealer, sometimes two coats since it dries really fast. Then I steel wool. You will be amazed. After that you can apply a finish, shellac works as a base for most common finishes.
- Model of CNC Machine: shark pro
Re: I am GROOT
I like it.He looks cool.Nice Routing.Plus you got to use your other tools.I have been working on the head of baby Groot.He is about 12 in high 8 wide.Good job. Basecircle
- Model of CNC Machine: FineLine Automation 4x4
Re: I am GROOT
I would seriously be interested in a baby Groot model!basecircle wrote:I like it.He looks cool.Nice Routing.Plus you got to use your other tools.I have been working on the head of baby Groot.He is about 12 in high 8 wide.Good job. Basecircle
- dwilli9013
Re: I am GROOT
Here is a number of them to choose which suits you.streetrodlover wrote:I would seriously be interested in a baby Groot model!basecircle wrote:I like it.He looks cool.Nice Routing.Plus you got to use your other tools.I have been working on the head of baby Groot.He is about 12 in high 8 wide.Good job. Basecircle
https://www.thingiverse.com/search?q=ba ... 8540252dad
D-Dub
Dwayne
Dwilli
Dwayne
Dwilli
- dwilli9013
