this is a companion piece to the firefighter I put up last month with the resulting embossing. 3" piece of brass for a wallet back plate.
don't worry, those tool marks are 0.15" below the surface so they won't show up on the leather as you can see.
firefighter companion piece in brass
- Model of CNC Machine: ULS M300, Rockler 60th Ann. Shark
"Out of my mind. Back in 5 Minutes."
- highpockets
Re: firefighter companion piece in brass
Thanks to some help from Nicksilva, I made my first embossing brass plate.
Made this for a friend of mine that does leather work as a hobby.
- dwilli9013
very cool. Love the look that leaves in leather. Thanks for sharing.
D-Dub
Dwayne
Dwilli
Dwayne
Dwilli
- scottp55
Looks GOOD John!
R.N.
R.N.
- highpockets
Well it didn't take long for my friend to start using the embossing plate.
- Model of CNC Machine: shopbot 4x8
- Model of CNC Machine: FLA Saturn 4x4 / 7W & 60W lasers
John,
Sorry for the what is probably an obvious answer, but... what is the embossing process after you have your plate made?
Dave
https://lakesedgewoodcraft.com/
- highpockets
Nick can answer this better, he told me. It's pretty simple, first use an unfinished piece of leather, wet it (doesn't have to be soaking). I used a block with a piece of rubber as a backing board and sandwiched the leather between the backer board and stencil. I then put the sandwich in a vice, you don't have go nuts cranking down on the vice, it really doesn't take much pressure.dah79 wrote:John,
