I was recently looking at some fossils and wondered about doing something similar in wood, I have seen some very well done fossil inlays using contrasting wood that are machined flat but I wanted to have the ‘bones’ left raised above the surface, also to have them look ‘boney’ so I used a white plastic panel that is normally used for cladding which is 10mm thick and has a smooth skin but a coarse middle section.
I used the normal V Carve inlay technique to cut into the base wood to form a good key for the glue as there would not be much surface area in places when I machined the ‘bones’ I then machined the underside of the plastic to mirror the wood and glued the parts together.
The following day I machined a 3D profile over the glued on face to leave the ‘bones’ proud of the wood, a bit of clean up to remove the fuzzes and a quick coat of lacquer to seal the faces.
Hope you like
Inlay with a twist
- Model of CNC Machine: Custom Made
- dwilli9013
Re: Inlay with a twist
Very nice and quite an interesting technique.
Thanks for sharing.
Thanks for sharing.
D-Dub
Dwayne
Dwilli
Dwayne
Dwilli
- mtylerfl
I like it!
- mfirlott
- Model of CNC Machine: Stinger 1 (2014)
Almost looks real! Well done.
(Mitch)
CAMaster Stinger I
Vectric Aspire
Epilog 45watt Helix Laser
CAMaster Stinger I
Vectric Aspire
- highpockets
Thanks everyone for the kind words
