CNC made bench and chair
- Model of CNC Machine: PDJ pilot pro
I used a corner chisel to square up the corners of the finger joint. I cut the left side first, and found it was a bit too tight, so I widened the joint by 0.001 on each side, and it fit perfectly.
I will modify the chair seat contour. The ridge in the middle is fine if you are sitting up perfectly straight, but becomes a bit...intrusive if you slide forward at all in your seat. The ridge in the bench is much more comfortable.
I cut all the parts on my CNC, and used my Aurio rasps (fantastic tools!) to do some profiling.
Re: CNC made bench and chair
Nice designs. Nice seat. I like the bench seat with the bottom profile.
Nice work. I like the artistic design, very eye catching.
- Creation in Wood
- Model of CNC Machine: Legacy Maverick ATC 4x8 CNC
