did some research into family coat of arms and found how to combine 2 nationalities on one plaque
Its a lot of work getting the components together takes about 1.5 hrs to get the graphics all set up
and do the node editing
This could also be run on the cnc router , using a fine end mill or v50 degree bit
family emblems or coat of arms
Re: family emblems or coat of arms
Always a mark of pride. I ended up doing about 6 different ones, then the business died out. Good Luck
- Model of CNC Machine: CNC Shark Pro Plus
Those are cool. I've made a few also. Your right though, the key is taking the time to edit. I used a .050 end mill on mine.
BillK
https://www.facebook.com/CarvingsByKurtz
