i made a new bench for my customer with a wildlifeszene , i make the szene with different models by myself. I was make it in oak, and for finish i use a spezial oil for outside.
the picture is 100 x 28 cm and 2 cm depth, the maschine need 16 hours to carve it
A new bench
Re: A new bench
Sehr schön
Re: A new bench
Ich schließe mich was Randall sagte.
- mikeacg
- Model of CNC Machine: Camaster Stinger, Sidewinder, SB 4x4
Re: A new bench
I like the bench design - simple yet elegant! The carving looks great as well! Did you run all 16 hours at one time or is it roughing and finishing paths?
Mike
Mike
- Model of CNC Machine: SHOPBOT BUDDY PRS 32, 4 FT PWR STICK
Re: A new bench
Excellent carving, i have used that same back ground scene on a few of my carving. Not many moose in my area so elk and mountain lions are the critter of choice.. I cant tell from the picture, but is the back piece one piece of wood or did you rip it and glue it back together.
Re: A new bench
the roughing path needs 1,5 hours, and the finish path wit a 3 mm ballnose needs 14,5 hoursmikeacg wrote:I like the bench design - simple yet elegant! The carving looks great as well! Did you run all 16 hours at one time or is it roughing and finishing paths?
Mike
Re: A new bench
it is make from one piece of woodCOWBOY1296 wrote:Excellent carving, i have used that same back ground scene on a few of my carving. Not many moose in my area so elk and mountain lions are the critter of choice.. I cant tell from the picture, but is the back piece one piece of wood or did you rip it and glue it back together.
- Model of CNC Machine: shopbot PRT Alpha 96x48
Re: A new bench
ganz ausgezeichnete Arbeit
