Elephant carving
Elephant carving
Postby tmccub530 » Fri Oct 14, 2016 7:55 pm
Hi all, I dowloaded a free vector art file which I was able to pull some texture from. I created some vectors from that, added flat shape height, and proceeded to use the sculpting tools and not too long after I had a nice carving. I ended up going back and doing some sculpting and carving some out of cherry. I used a offset roughing with a raster angle of 90 to go with the grain of the wood for finishing. 6mm EM to clear and 1/16" tapered ball from amana tool. Then It was profile cut through with an 1/8" EM. Any tips on CV settings for mach 3 would be helpul by the way, I am rookie cnc machinist. Thanks for any suggestions.
Final carving after using the sculpting tools.
This is the first test carving.
Mirrored Elephants
tmccub530
Model of CNC Machine: DIY Kit From CNC Conversion kit
Re: Elephant carving
Postby mtylerfl » Sun Oct 16, 2016 12:39 am
That's pretty cool!
Postby TReischl » Sun Oct 16, 2016 2:44 pm
Nicely done!
About those CV settings. . . we all seem to have our own opinion of what is optimum. It takes a bit of "thinking" when looking at them and then doing some experimenting.
Postby tmccub530 » Sun Oct 16, 2016 8:35 pm
Thanks fellas! Thats what I've been reading on the cv settings. Itworks great (for what it is) but shakes a little more now that its not rounding the corners at faster speeds. Maybe i weld a few more supports for the base to keep everything a bit tighter. Thank you
tmccub530
Postby martin54 » Sun Oct 16, 2016 10:06 pm
Like that it looks really good :lol: :lol:
As for cv settings as Ted has said it really is about a bit of trial & error, so many differences from machine to machine that using someone else's settings won't give the best results for your machine unless you got really lucky :lol: :lol:
Postby tmccub530 » Sun Oct 16, 2016 11:41 pm
:D Thanks Martin, I found out a little late but I had to make a lotus flower instead so Im carving that out now :D I toned down my acceleration and adjusted my cv distance units again. seems a little less shaky. Maybe I tone down my accel a little more.
tmccub530
Postby ger21 » Mon Oct 17, 2016 3:51 pm
Turn off CV Distance and CV Feedrate.
ger21
Postby tmccub530 » Mon Oct 17, 2016 5:56 pm
Thanks man. I'm going to try that out next chance I have.
tmccub530
Return to Aspire - Gallery
Users browsing this forum: No registered users and 18 guests
