Just for fun again
Just for fun again
Postby plcamp » Sat Dec 19, 2015 2:12 pm
Upon completing my machine and before installing a control pendent I would set Z0 manually. I would turn the controller off and turn Z stepper shaft with a small wrench until the tool touched the material surface. This actually works quite well but using the wrench was a bit troublesome so I designed a simple knob to replace the wrench, and since the knob is attached to the motor shaft the procedure became alittle esaier.
So, as with the first knob I posted this one that may prove of some value and if nothing else it covers the open end of the motor shaft.
PLCamp
knob.zip
(328.04 KiB) Downloaded 162 times
plcamp
Model of CNC Machine: Home built wooden machine - Mach3/Aspire
Return to Aspire - Gallery
Users browsing this forum: No registered users and 15 guests
