Text on text wedding sign
Postby tonydude919 » Sat Sep 26, 2015 5:47 pm
Text on Text wedding sign. Size is 7" x 13" made out of cherry , took about 4 hrs to carve using a .125 ball nose bit with a 8% stepover on bit.
Tony
tonydude919
Model of CNC Machine: cnc mako shark ext bed with HD 5 gantry
Re: Text on text wedding sign
Postby woody53 » Sat Sep 26, 2015 6:05 pm
Lookin good , as always , Tony. Cherry carves good for me.
Dave
woody53
Model of CNC Machine: Probotix Meteor 25 x 50
Postby scottp55 » Sun Sep 27, 2015 2:02 pm
NICE Tony!
Can't quite tell if top layer was pocketed first?
Was top layer painted white before carving second layer, or all layers painted afterwards?
Nice 3D touches.
GMH
scottp55
Postby tonydude919 » Sun Sep 27, 2015 3:35 pm
Scott,
The sign was done in one pass. Used a .125 ball nose bit. I did a 3d finish toolpath only. I create shape from vectors. I used sharpie marker pens after the whole sign was carved.
Tony
tonydude919
Postby scottp55 » Sun Sep 27, 2015 3:59 pm
Ah...Aspire.
Was the .125"BN a Tapered? Or did a standard BN manage that 2XDiameter initial cut OK?
I'm always way to cautious on pass depths. But just getting into 3D so my BN bits are really limited and virtually never do mid or big size stuff and it's good to know. Still using engraving bits here for my teeny stuff because detail is better even than a 1/64"BN and I can do no roughing cuts on the dished buttons.(and 64'ths scare me) :)
Thanks Tony
(Sharpies? Going to have to scope that out...thanks!)
GMH
scottp55
Postby Merrick » Fri Oct 09, 2015 1:16 pm
Nice work. Where did you get the hearts model?
Merrick
Model of CNC Machine: Cncrp pro
Postby joejinky » Sun Oct 11, 2015 11:05 pm
Will V-CarvePRO do that text-on-text technique, or do I need to upgrade to Aspire?
http://flic.kr/s/aHsk7y47ff
joejinky
Model of CNC Machine: Samson 510 CNC Plasma Table
Postby tonydude » Mon Oct 12, 2015 12:46 am
You can do it in vcarve pro if you weld the text. Somebody did a write up on doing text on text for v carve pro. The way I do it I only use a .125 ball nose bit one pass. The lettering is modeled with a 22 deg angle on them.
Tony
tonydude
Postby tonydude » Mon Oct 12, 2015 12:50 am
You can read this post. viewtopic.php?f=5&t=22609
Tony
tonydude
Postby scubanimal » Thu Oct 15, 2015 10:56 pm
Beautiful, while I think doing the actual modeling and CNC work is doable, how you are able to finish/paint it I think is just another skill that makes your work such a stand out.
Very cool!
scubanimal
Model of CNC Machine: Stinger1 24, Shark HD2 Pro, Aspire,
Postby tonydude » Fri Oct 16, 2015 12:56 am
I use paint markers or sharpies. Than I spray couple coats of clear finish on it.
Tony
tonydude
Postby Stomper2k » Sun Mar 13, 2016 7:39 pm
Ive done these similar signs using 2 pass method, 1 for each layer.
Could you message me a brief tutorial to set up for a 1 pass project?
Very well done
Also my ball nose bit does leave tool path markings in end result. would a flat end mill eliminate these markings? and maybe just use the ballnose for icons or models. thoughts?
Stomper2k
Model of CNC Machine: Digital Wood Carver
Postby jprimus » Tue Jan 01, 2019 8:34 pm
Do you by chance have a file to purchase? I’d love to see the set with one pass.
Thank you
jprimus
Model of CNC Machine: shark hd 4 extended bed
Return to Aspire - Gallery
