by jarm2 » Wed Jul 29, 2015 10:38 pm
This is my attempt at the cannon that was shown in an earlier post. I added the rammer and a stack of cannon balls. The cannon was cut from fir dimension lumber and the balls from 1-1/2" thick lumber. I cut each layer using two sided methods and then glued the layers together. Painted with oil based exterior paint. Trunnion hold downs are made from paperstone for strength.
Vectric Aspire, Cut3D, VCarve Pro, AutoCAD lite, Draftsight, Corel Draw X6, ViaCAD Pro 9, W 10
