Wall Panels
Wall Panels
Postby buck4 » Fri Jul 24, 2015 11:25 pm
Finished the wall job for Bay County Road Comm. and Water & Sewer Department.
16 panels each 2 foot square and 1 1/2" thick solid hard Maple.
Aspire Rocks !!!
buck4
Re: Wall Panels
Postby Rick O. » Sat Jul 25, 2015 12:15 am
Nice!
Wondering.. how are they mounted?
RickO
Rick O.
Model of CNC Machine: CNC router
Re: Wall Panels
Postby Ms Wolffie » Sat Jul 25, 2015 11:30 pm
Niicee :)
What a job
Cheers
Wolffie
Whatshammacallit
Ms Wolffie
Re: Wall Panels
Postby Arbo » Sun Jul 26, 2015 1:46 am
Nice work.
Arbo
Model of CNC Machine: home built
Re: Wall Panels
Postby alex wight » Sun Jul 26, 2015 10:47 am
Lovely job
alex wight
Model of CNC Machine: DIY
Re: Wall Panels
Postby MTSO » Sun Jul 26, 2015 8:13 pm
Looks fantastic. Question, is there a tutorial for how you set multi sheets in Aspire?.
regards
Brian
MTSO
Model of CNC Machine: salecnc XJ1224
Re: Wall Panels
Postby buck4 » Sun Jul 26, 2015 10:07 pm
MTSO, each panel was done as its own profile, all the fonts had to be redone and changed into a true type fonts because the designer wanted sharp corners and the out line of the county was taken off a bit map. With the panels spaced 1 3/4", lots of vector lines and node editing. (total time in Aspire was approx 16 hours) sure there are many members that could cut that time in half.
Rich O, I was commissioned to carve the images onto the panels, the contractor supplied all the material, and hung the panels on the wall. I did sent a email with the same question you ask, I will let you know when he apply s back.
buck4
Re: Wall Panels
Postby buck4 » Sun Jul 26, 2015 10:20 pm
Brian MTSO, this may give you an insight on how I did the complete wall. Layed all the 2' sq panels spaced 13/4" apart. Droped in the bit map and started drawn. Then each panel was made into its own file, to create the tool paths and machining.
buck4
Re: Wall Panels
Postby buck4 » Mon Jul 27, 2015 2:32 pm
Rick O, the answer to your quwstion, is they used Monarch Z Chips
http://www.monarchmetal.com/z-clip-selector-tool/
buck4
Return to Aspire - Gallery
