Tycho Crater
Tycho Crater
Postby finkh » Fri Feb 27, 2015 5:21 pm
Tycho Crater produced from data gathered by Laser Altimeter onboard Lunar Reconnaissance Orbiter.
1:500,000 scale, vertical exaggeration 4x.
2nd growth yellow pine salvaged from 3 x 12 joists removed from gut rehab of Manhattan sweatshop built in 1920's. 1/8" tapered ball-nose cutter from precise bits for finishing pass took about 90 minutes: a hundred passes to the inch for about 1000 passes.
This will be used on a thermoforming machine to make copies in .020 polystyrene and then painted in relief.
finkh
Model of CNC Machine: Romaxx WD-1
Re: Tycho Crater
Postby Zambrano » Sun Mar 01, 2015 1:55 pm
Do You have stl file?
Miguel
Zambrano
Model of CNC Machine: Home made CNC Router
Re: Tycho Crater
Postby finkh » Sun Mar 01, 2015 3:36 pm
Yes. what would yoy like to do with it? I have a number of locations in preparation.
finkh
Re: Tycho Crater
Postby scottp55 » Sun Mar 01, 2015 4:18 pm
By the way......GREAT JOB!! :)
GMH
scottp55
Re: Tycho Crater
Postby mikeacg » Mon Mar 02, 2015 1:43 pm
Impressive!
That would make a great wall texture tile...
Mike
mikeacg
Re: Tycho Crater
Postby Vfxdaddy » Mon Mar 02, 2015 2:05 pm
Very nice!
I would also be interested in the .stl file. I like to play with my machine and learn while playing with it.
Vfxdaddy
Model of CNC Machine: Laguna Swift
Re: Tycho Crater
Postby hannamand » Thu Mar 05, 2015 6:55 pm
Very cool... Have you thought about doing a YouTube Video of how you create the files?
I've kicked around the idea of doing this for earth topography, For instance if a city wanted a relief map of their city limits to hang on the wall of city hall...
hannamand
Model of CNC Machine: Camaster Stinger w/recoil
Re: Tycho Crater
Postby JDHTech » Thu Mar 05, 2015 6:57 pm
As an amateur astronomer and CNC nutcase, I would also like to share in your data for personal use only.
JDHTech
Model of CNC Machine: Blacktoe
Re: Tycho Crater
Postby rloncohen » Wed Mar 11, 2015 4:54 am
hi,
can you please tell me what process you when thought to obtain the data. it is a bit complicated! which mission, instrument, data set and any tips would be very appreciated.
sincerely,
richard cohen
rloncohen
Model of CNC Machine: romaxx
Re: Tycho Crater
Postby finkh » Wed Mar 11, 2015 3:25 pm
https://finkh.wordpress.com/ is the site I use for astro stuff.
https://finkh.wordpress.com/3d-workflow/ has some instructions which may be a shade out of date; the PDS site changes regularly. You want to find a page with a Data Set Browser tab and then click it to get to LOLA.
For Mars and other worlds, the data is in .img format, which needs a GIS (Geographic Information System) to convert to a tiff file that Mathematica uses. I will tackle those this summer.
If you can live with equirectangular format and don't mind the lack of curvature, you can download .jp2 LDEM files (you will need a converter for photoshop but there are free ones available) and crop to get a grayscale that should open in aspire, after saving as a tiff or png. (both 16-bit) formats. (NASA doesn't seem to mind http://nasa3d.arc.nasa.gov/detail/moon-nearside-farside) Don't use jpeg as it is eight-bit.
finkh
Re: Tycho Crater
Postby rloncohen » Tue Mar 24, 2015 3:29 am
i sincerely thank you for the information.
rich
rloncohen
Return to Aspire - Gallery
Users browsing this forum: mickecarlsson and 8 guests
