Fishscale wallet back embossing plate
Postby nicksilva » Sun Oct 26, 2014 6:14 pm
This is a new wallet back embossing plate cut into delrin.
I took a fishscale (or dragonscale if you prefer) checkering pattern and transfered it over.
I've added a closeup of the scales. I'm thinking of redoing this and adding just a hint of a
border to better protect thos outside scales, but otherwise pretty pleased with it.
this was cut with a 1/16th bullnose.
Cheers!
"Out of my mind. Back in 5 Minutes."
nicksilva
Model of CNC Machine: ULS M300, Rockler 60th Ann. Shark
Re: Fishscale wallet back embossing plate
Postby glenninvb » Sun Oct 26, 2014 7:43 pm
Your gonna make me take up leathercraft, :) that's very nice looking!
What is the procedure for stamping, type of press, wet leather????
That looks like a piece of HDPE? But it's White Delrin?
glenninvb
Model of CNC Machine: homebuild / VCP 8.0
Postby nicksilva » Sun Oct 26, 2014 8:51 pm
Yes, it's white delrin 1/2" thick.
The leather should be wet. That softens the cells so it can stretch and take the impression and once it dries it will hold the shape.
this was pressed using my 1 ton arbor press. I back it with a thick piece of leather or rubber so that it presses the leather up into the
recesses. If that's not enough, I also have a 12 ton bottle jack press that will take care of business. but 1 ton is usually enough.
Delrin is my material of choice but most anything can be used. It only has to be harder than leather to work.
Cheers!
nicksilva
Postby scottp55 » Mon Oct 27, 2014 10:54 am
Very nice! Came out great :)
GMH
scottp55
Return to Aspire - Gallery
