Another little Aspire job
- Model of CNC Machine: salecnc XJ1224
Re: Another little Aspire job
Love it, i have always wanted to make a Moai. i would love to know where you got your 3d file of it?. You say that it sits on a frame, do you have any construction photos they would be interesting.
Really monolithic looking.
Regards
Brian
Regards
Brian
- mezalick
That's no small feet......or is it feat....(pun intended)
Nice work.
Michael
Nice work.
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
That is gorgeous Henry. It might replace the Aztec calendar as the must-do project.
How did you slice that monster?
Paul Rowntree
- dhellew2
Really great work. I must try slicing one of these days. Dale
Young = time, no money
Old = money, no time
Dale
Dale
- Henry B
- Model of CNC Machine: Kimla CNC
I sliced it using 100mm sheets 2000mm x 1000mm, it was 9 pieces i think, i made it all with a 12mm bullnose in one pass, I mounted a 2.5m long aluminium pole in the middle 50mm wide 4mm thick, I then welded pieces that were 250mm long either side, routed that shape in the middle, then glued it all together with an MS polymer glue, the routed a round plate with 51mm hole in the bottom, welded that to the tube having glued it to the bottom of the model. It then sat in a 600m steel tube that was mounted in a concrete foot 500mm high same as is used for road signs.
Not sure if I can post a video link here
<iframe width="420" height="315" src="//www.youtube.com/embed/0G0WRtbDluE" frameborder="0" allowfullscreen></iframe>
