Baccarat Board
Baccarat Board
Postby dealguy11 » Tue Aug 26, 2014 3:00 am
Here's another commissioned piece that Aspire made possible. Customer asked for a Baccarat board with this design. With the addition of a few simple inlays and some v-carving, we were able to really exceed his expectations. The board is birch, the inlays are walnut. The large card trays are bookmatched. All of the lettering and lines on the board are just v-carved with paint added to highlight them. The logo at the top was v-carved and painted. Size is about 19" x 25".
Steve Godding
dealguy11
Re: Baccarat Board
Postby glenninvb » Tue Aug 26, 2014 3:18 am
First class!!!
Outstanding work
glenninvb
Model of CNC Machine: homebuild / VCP 8.0
Re: Baccarat Board
Postby John Murphy » Tue Aug 26, 2014 3:29 am
Sweet!
Very well done!
John Murphy
Model of CNC Machine: AXYZ 5010
Re: Baccarat Board
Postby scottp55 » Tue Aug 26, 2014 9:36 am
Beautiful Work! :)
GMH
scottp55
Re: Baccarat Board
Postby martin54 » Tue Aug 26, 2014 1:18 pm
That looks really good, simple design but so effective with the different wood choices, only thing I would have liked to have seen done differently would be the Logo at the top, personally think the white rectangle around the logo could have been lost.
Re: Baccarat Board
Postby dealguy11 » Tue Aug 26, 2014 3:00 pm
I didn't really want the white either, but that was part of the design. It also helped to hide some burn marks in the wood. Our new 60-degree v-bit turned out to something less than 60 degrees and dug in on the corners and a few other areas. The bit actually appears to be less than 55 degrees based on running the standard v-bit tests - should have run them before we cut this. I've never had that issue with the CMT laser-point bits before.
Steve Godding
dealguy11
Return to Aspire - Gallery
Users browsing this forum: No registered users and 18 guests
