Lamp Table
- Jerry In Maine
- Model of CNC Machine: CNC Router Parts CRP4848
Lamp Table
This little table was inspired by an antique table I got at auction 20+ years ago. Made of pine, top and sides are 3/4" thick while center brace is 1/2".
Sides and top are machined on both sides....the top has pockets underneath for the side to slip into and the sides are pocketed to accept the center brace. Wooden buttons on the sides hide the screws holding it together
Its low profile...meaning it doesn't call much attention to itself and doesn't stick out far from the wall so its good for spots too tight for larger tables.
This was my first piece of "furniture" done with Aspire and I'd be happy to post the files if there's any interest. It makes for quick project and you've likely got enough scrap laying about to make at least one.
I'm just a number in a great design
- mtylerfl
Re: Lamp Table
Very nice table, Jerry!
- Model of CNC Machine: Shark Pro Plus
Re: Lamp Table
Jerry,
Very nice!
What are dimensions?
Please post as myself and others would be interested.
Very nice!
Eric
The WoodEraser
Liberty Twp (N. of Cincinnati & S. of Dayton) Ohio
The WoodEraser
- Jerry In Maine
Re: Lamp Table
size is 24" high x 24" wide by 12" wide
Here's the files:
The top uses a 1/2" ball nose to enhance the edges. 1/2" wood dowels are on the top and sides to line the stock up when flipping to machine the back side. The 1/2" wood "buttons" on the sides that cover screws are available at lumber stores.
Here's the files:
- Jerry In Maine
Re: Lamp Table
I typo-ed the dimensions...actually they're size is 24" tall x 24" wide by 12" wide.
I used white pine and applied the finish before assembly. The top and side pockets are .02" oversize to ease assembly, but one thing I found is that white pine swells a bit when a finish is applied. This made the top and side pockets a very tight fit.
If you plan to finish before assembly you might want to make the pockets a bit larger...maybe .04", just in case the wood swells.
Re: Lamp Table
Thanks Jerry!
Paul Rowntree
- Ms Wolffie
Re: Lamp Table
Just the way I like things, simple and non-intrusive.
What's that long white thing on the wall?
If it is a heater won't it interfere with timber movement?
BTW. Thanks for the files
Cheers
Wolffie
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- bill_w
- Model of CNC Machine: PRSalpha BT48
Re: Lamp Table
hi Jerry,
That is a fine looking table, verry nice
and thank you for your files.
Computers-Yuk....I should junk it...It never does what it should do...only what I tell it.
Re: Lamp Table
Thanks Jerry for the files.
Eric
The WoodEraser
The WoodEraser
- Leo
Re: Lamp Table
Awesome Jerry - simply gorgeous
- Jerry In Maine
Re: Lamp Table
That's the baseboard heat. Common in cold weather climates like New England. Theyre installed throughout the house. Hot water circulates in them and when the slot at the top is open warm air comes out.Ms Wolffie wrote: What's that long white thing on the wall?
Wolffie
Fuel oil is expensive these days so we don't use them much. We now heat mostly with wood pellets in a centrally located pellet stove. Its much like a common wood burning stove.
- Model of CNC Machine: Probotix Asteroid
Re: Lamp Table
Looks awesome. I'm going to attempt to make one for my wife for Valentine's Day. Thanks so much for the files:)
Rick Melendez
