Help with Project to Surface
Postby Len-Tikular » Tue Jan 28, 2014 11:03 pm
I need a little help with projecting my Alvis text and triangle onto a domed piece of Aluminum.
I only need to carve 3/4mm deep but I want to ensure even depth on the workpiece.
I.m using the 'Project vector' onto the workpiece but it's not working for me. Clearly I've missed the point.
I would appreciate any help.
Many thanks
Alvis.crv3d
(37 KiB) Downloaded 90 times
Len-Tikular (A glider pilots dream cloud)
Aspire v4.0
Len-Tikular
Model of CNC Machine: Home made revision 3
Re: Help with Project to Surface
Postby Mike-S » Tue Jan 28, 2014 11:25 pm
Can you post what is going wrong.
Seems OK to me.
Mike-S
Postby Len-Tikular » Wed Jan 29, 2014 1:15 pm
Many thanks for your reply,
Can you help with the process you followed and what is the best tool to use considering I only want to go 30 to 40 thou deep.
I created a component from a circled and then applied a 10 degree dome to it,
I then created my toolpath and mapped the log to the surface.
Also, I need the reverse of what you have shown. Please see pic attached.
Many thanks
George
Aspire v4.0
Len-Tikular
Postby Mike-S » Wed Jan 29, 2014 3:58 pm
You need to shrink the logo a little and then put an off-set vector (3-4mm) around the triangle. That provides the needed second vector to do the V-carve. Try a 90 deg V-bit.
Mike-S
Return to Aspire - Gallery
Users browsing this forum: Google [Bot] and 9 guests
